As the title says, which card should I get, a 980Ti reference or ACX 2.0? I really like the reference design, but I'm worried about thermal throttling and the noise of the blower fan under load, will the reference cooler be much louder than the ACX?
Here's my build:
  • Motherboadrd: Asus Z97I-PLUS
  • CPU: Intel i7 4790K
  • CPU Cooler: Noctua NH-U14S
  • RAM: Corsair Vengeance Pro Series 16GB (2x8GB) DDR3 1866 MHZ
  • PSU: EVGA SuperNOVA 650 GS
  • Fan 1 (Intake): Corsair AF140 White LED
  • Fan 2 (Exhaust): 120mm
  • Case: BitFenix Prodigy Mini-ITX Black
PS. What do you think about my build? I still don't have it yet it's still being shipped, but I can provide photos after all the parts arrive.
https://linustechtips.com/topic/378923-980ti-reference-or-acx-20/
Acx 2.0 will run much cooler and quieter I'd imagine.
Here's my build:
ACX 2.0 much better cooler
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
Eather EVGA, Or that nice looking Zotac amp extreme edition
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
reference looks so good thow
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
acx 2.0
on a side note , how long untill ppl realise the titan x cooler will fit the 980ti and sell them as fake titan x cards ? (just a thought i had whilst thinking about life xD)
Please quote me or tag me if your trying to talk to me , I might see it through all my other notifications ^_^
the current list of dead cards is as follows 2 evga gtx 980ti acx 2.0 , 1 evga gtx 980 acx 2.0 1600mhz core 2100mhz ram golden chip card ... failed hardcore , 1 290x that caught fire , 1 hd 7950 .
may you all rest in peaces in the giant pc in the sky
http://www.anandtech.com/show/9306/the-nvidia-geforce-gtx-980-ti-review/16
This review was conducted of the reference 980 Ti. The "average clockspeed" table near the beginning should give you an idea what to expect from thermal throttling—that is, not much. One of the reasons given for it's excellent performance just shy of the Titan X is because it seems to end up at higher clock frequencies.
That said, I'd probably lean toward a third-party cooler just because I'm sure it would throttle even less and allow for a better overclock.
Same boat as OP, I am thinking about the 980 Ti reference card. I need a GPU and can't wait around any longer for EVGA. I don't mind noise whatsoever. I am just contemplating how to keep the GPU temps in the 70's on air. I eventually want to do SLI. And the reference is so damn sexy.
CPU: Intel Core i7 7820X Cooling: Corsair Hydro Series H110i GTX Mobo: MSI X299 Gaming Pro Carbon AC RAM: Corsair Vengeance LPX DDR4 (3000MHz/16GB 2x8) SSD: 2x Samsung 850 Evo (250/250GB) + Samsung 850 Pro (512GB) GPU: NVidia GeForce GTX 1080 Ti FE (W/ EVGA Hybrid Kit) Case: Corsair Graphite Series 760T (Black) PSU: SeaSonic Platinum Series (860W) Monitor: Acer Predator XB241YU (165Hz / G-Sync) Fan Controller: NZXT Sentry Mix 2 Case Fans: Intake - 2x Noctua NF-A14 iPPC-3000 PWM / Radiator - 2x Noctua NF-A14 iPPC-3000 PWM / Rear Exhaust - 1x Noctua NF-F12 iPPC-3000 PWM
If you don't mind the noise at all, and you're absolutely sure that you'll SLI, then I think that the reference will be the right one for you, just set an aggressive fan curve, and you'll be golden.
Yeah I saw the article earlier and that was pretty much the same conclusion I came to.
Thanks. Is there a good way to set a fan curve, like a 'standard' people go by or what do you recommend to keep it cool? Like I said, noise doesn't bother me, just temps.
You're welcome, I have no experience in this whatsoever, though I imagine that a balance between temperature and fan speed in a way where there would be a diagonal line going from 0RPM/60C to whatever maximum temperature/RPM you're comfortable with ( max temperature should be not more than around 85C), would be the most ideal. With that in mind, I would highly advise you to do more research on this matter.
