Skyrim oh skyrim..
Go to solution Solved by CalculuS,
Sounds about right.
So I just bought an R9 280X today, current setup other than that being an AMD FX-4300 8GB ram, pretty basic really. Every other game, tomb raider, evolve, all work fine at highest settings.. I open up skyrim, ultra, and in some cases even lowering settings like turning shadows low, I get 40 normally, and 20-30 staring over all of whiterun from dragonreach. All my drivers are installed, v-sync the nasty bugger is turned off. So what could be causing this issue? Again it's just this game.
https://linustechtips.com/topic/378359-skyrim-oh-skyrim/
Damn, Did you uninstall old graphics drivers if you had any installed? and what is your cpu usage at when playing skyrim?
https://linustechtips.com/topic/378359-skyrim-oh-skyrim/#findComment-5113143
Could be an issue. Mind telling me how I can safely uninstall old drivers?
http://www.howtogeek.com/howto/windows-vista/remove-old-drivers-after-upgrading-to-new-hardware/
https://linustechtips.com/topic/378359-skyrim-oh-skyrim/#findComment-5113198
Do you use ENB? The enblocal.ini will screw your framerates if you dont properly set it up for a new GPU.
“I don't like country music, but I don't mean to denigrate those who do. And for the people who like country music, denigrate means 'put down'.” - Bob Newhart
Remember kids; just because Linus has a video on it, doesn't mean that its the best choice Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/378359-skyrim-oh-skyrim/#findComment-5116915
-snip-
1. Do you have any mods installed?
2. How is your CPU usage looking?
https://linustechtips.com/topic/378359-skyrim-oh-skyrim/#findComment-5116937
I think it is time you ditch your AMD cpu...
https://linustechtips.com/topic/378359-skyrim-oh-skyrim/#findComment-5117012
I appreciate the kind reply about it :) Yeah I'm going to upgrade to an intel I5 4960K? I believe that was the one.
Just a small typo - it is the 4690K :P but yeah, that one is the go-to for good gaming :) Oh, and don't forget to change the motherboard also :D
https://linustechtips.com/topic/378359-skyrim-oh-skyrim/#findComment-5125880
