Terve!
I am using NZXTs big boy fans. They are reasonably quiet but I cannot tell you what corsair 200mm fans sound like.
Generally the noise is not the problem at these sizes, because they cut down the RPMs to reduce the niose.
If they are not too loud for you and you have enough cooling potential, I would stick to the Corsair Fans.
Maybe there is a sticker on the fans that tells you the model. With that you could google some reviews of the fan.
Also: If you go Noctua don't be fooled by their name and take 3000 RPM fans (industrial). They are still 3000 RPM fans.
They move a lot of air, but they make a lot of noise.
For suggestions of Noctua fantypes, you should post a picture of your PC and tell us what you are using.
Sayonara!
https://linustechtips.com/topic/378036-200mm-fans/#findComment-5109063
