So Ive finally done it after what, 2 years of not much folding? haha xD
Couldnt use my GPU's due to the heat for the longest time, then I decided one day a couple months ago that I should just use my CPU and see what happens and it worked quite well. Glad to be folding for LTT and I will keep on for the benefit of mankind haha
link to my stats: http://folding.extremeoverclocking.com/user_summary.php?s=&u=645937
pic:
post-15957-0-60632900-1433103993_thumb.p
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
https://linustechtips.com/topic/377522-finally-1-million-points/
Great job!
I still need to get my badge,,,
00110000 00110001 00110000 00110000 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110001 00110001 00100000 00110000 00110001 00110001 00110001 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110001 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110000 00110001
https://linustechtips.com/topic/377522-finally-1-million-points/#findComment-5102533
