switch that fan round on the heat sink and have 2 intake on the front
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/377405-cpu-overheating/#findComment-5101234
the fan on the cooler, is fighting the one t the back of the case, as they are opposite to eachother.
swap one or the other. maybe leave the cpu cooler as it is, and have the one at the back of the case as an intake, to feed the cpu cooler with cool air (you will have to deal with the dust though)
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/377405-cpu-overheating/#findComment-5101237
what are your other specs like? cpu and such..
is your thermal paste properly applied and cooler secured right?
do your fans run at 100% under load?
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/377405-cpu-overheating/#findComment-5101243
that too. didnt see that
https://linustechtips.com/topic/377405-cpu-overheating/#findComment-5101247
Turn the fan on the cooler around, and make sure the front fans are intake. Currently, you have the rear fan pulling air out of the case and the fan on the cooler pulling air through the cooler; yet the rear fan is pulling all the air away from the cooler, so as someone else said they're fighting for air.
https://linustechtips.com/topic/377405-cpu-overheating/#findComment-5101319
That cooler and fan look a bit on the small size for an FX8370.   The high-end FX series chips are like tiny furnaces.    A cooler with more surface area and a 120mm fan should get the job done.
http://www.outletpc.com/ak6964.html?gclid=Cj0KEQjw4qqrBRDE2K_z7Pbvjo8BEiQA39AImdV6BpehqVuVBWDC6KY2MpN2cV8H97zCG2ciqgYn-RMaAow-8P8HAQ
I have one of those in my case and my Phenom X6 running at 125W+ rarely gets over 32c.  And it looks really good.......
https://linustechtips.com/topic/377405-cpu-overheating/#findComment-5101942
