So I have tried 4 times to get razer comms to work.
Every time I use the installer and it works fine. Then when i go and click the short cut it says
3QMiBgJ.jpg?1
So then i click browse and i have looked through every folder and not a single one has the razercore.exe file.
so then i uninstall and try again, ive even tried getting another installer but it wont work.
Am i doing something wrong?
I tried installing razer synapse 2.0 and it worked fine but i dont know what the matter is with comms.
Please help
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/37644-help-installing-razer-comms/
Check where it installs the application and go to that location and click on one of the .exe's that might launch it :P
I have, it didnt work
C:>Program Files (x86)>Razer>Core>RazerCore.exe
Should be there
You may have to reboot for it to work, I just re-installed
Can you find the folder, it just doesn't have the exe in it?
Its not there, there is not a single application called. Razercore.exe at all nothing no where ive looked nothing ive tried everything i know of.
Is the Razer folder there?
Yes, and when i go into it this is what is there
wRpqa4l.jpg?1
Ive clicked the setup thing and it still doesnt work after.
Just look it up manually, that open window is probably just looking for specific file types.
Follow the path I posted and see if it's there. If it is and it works create a shortcut from it.
I did and it wasnt there.
I dunno then, if you have reinstalled and rebooted, the only other thing I have to suggest would be to download the installer again, doubt that's the problem but the only thing I can think of.
I have like 3 times
Maybe your pc just doesn't support it. Are there 32 and 64 bit installers?
Not that i saw
Here's what should be in your older:
Navigate to it by going through "My Computer" and post your folder up
Again, i did, but it wasnt there. at all
Was everything else there?
Yup
Protip, restart an let it open it's self.
"You know I was taught that if you don't have anything nice to say, don't say anything at all. You feeling me cocksucker?"
"Ethernet is internet juice. You have to press the internet really hard and you will get it."
"My quantum milk machine brings every boy to all the yards." non futuis et sursum
PC Specs! | I7-950 | 24GB RAM | 10TB Storage | GTX 970 Strix and a 560TI DCUII for Physx | 120GB 840 + 250GB 850 EVO | Asus xonar DGX
Please take a moment to look over the forum CoC here.
Yup
try installing synapse it also installs razercore.exe
Rig 1 CPU: 3570K Motherboard: V Gene GPU: Power Color r9 280x at 1.35GHZ  RAM: 16 GB 1600mhz PSU: Cougar CMX 700W Storage: 1x Plexor M5S 256GB 1x 1TB HDD 1x 3TB GREEN HDD Case: Coolermaster HAFXB Cooling: Intel Watercooler
"My day so far, I've fixed 4 computers and caught a dog. Australian Tech Industry is weird."
"It's bent so far to the right, It's a hook."
I did and it still didnt work.
Did you try turning it off and on again?
yes.
