Hello,
Can someone help me? Im a noob with computers i've out thos together https://gyazo.com/22d819bc01eb0ddc5446c5aa57224b3e if i buy this do you guys think im able to play with a 4k monitor? :D Gyazo is just a screenshot so its not a virus. Hope someone can help me and give me some tips what i need to upgrade or maybe need to lower so the budget goes down :D Thanks in advance
https://linustechtips.com/topic/375402-can-someone-help-me-d/
use PC part picker you can link directly to the build...less sketchy
(for all those sketched link is legit its just a picture)
as for 4 k I really dunno I game on most 3 1080 monitors for some older stuff or one for newer stuff..so I dunno how hard it is to push 4k ..I know its not easy though and you need to start spending some big bucks to do it.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/375402-can-someone-help-me-d/#findComment-5077381
Welcome to the Forum.
We know that Gyazo is a screenshot tool.
First off, please use http://pcpartpicker.com
Second thing, what's your budget and location?
Third thing, please don't use the Kingston V300.
then here's my opinion. For gaming you really don't need more than an i5 or i7 on Z97, so there's no point in going X99. Also DDR3 is cheaper than DDR4 so you'll be saving some there. Then you should spend the rest of your budget on a better SSD and graphics.
Sig under construction.
https://linustechtips.com/topic/375402-can-someone-help-me-d/#findComment-5077382
Hello,
is this a gaming PC? used for editing? what do you plan to use it for?
because just for gaming, you should not be spending so much on the x99 platform+cpu. could put more towards the graphics card
https://linustechtips.com/topic/375402-can-someone-help-me-d/#findComment-5077397
And a 970 and that i7 dont need a 1000w
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/375402-can-someone-help-me-d/#findComment-5077421
Wow thanks for all the fast reactions im using this for pure gaming IM from the Netherlands ( Europe ) they use euro's im willing to spend like 2500 to 3000 euro that like 2715,75 USD to 3258,90 USD. Thats just for the pc. Thanks again for all the tips.
https://linustechtips.com/topic/375402-can-someone-help-me-d/#findComment-5077504
Seeing that shoppingcart, I assume you're buying from Afuture? :P
You know, you can make your wishlist on Tweakers.net and it will calculate the cheapest solution with different stores, it's like PC Part Picker but for the Netherlands.
Added, I don't think a single 970 is going to be happy at 4k resolutions. I don't have ANY experiences with it, so I'm not sure.
New to Star Citizen? Look no further!
https://linustechtips.com/topic/375402-can-someone-help-me-d/#findComment-5077514
Yes indeed that afuture :P Well i can make a wishlist but i really don't know alot about pc so first things first i really wanna know whats the best setup for a 2500-3000 euro. Already seen some good tips here helps alot :D
https://linustechtips.com/topic/375402-can-someone-help-me-d/#findComment-5077544
So what cpu+platform do you think is good enough? And also what Graphic card something like the titan? Or maybe 2 cards?
https://linustechtips.com/topic/375402-can-someone-help-me-d/#findComment-5077594
look at the 1150 socket. just pick up a normal I7, then with the money you save on ram+mobo+cpu, you will have much more to put towards graphics cards.
basically with gaming, if you get any I7, you can throw any graphics cards at it. and graphics cards are what determine most of gaming perfomance. id look at the 295x2, as it lately just took a massive dump in price, or if you want to stay nvidia id look at the titanx, or 980. the 970 isnt the most powerful card in the world, and it has less VRAM. for higher resoultions, such as 4k, you want more Vram
https://linustechtips.com/topic/375402-can-someone-help-me-d/#findComment-5077636
