CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  (£143.44 @ Ebuyer)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  (£31.98 @ Ebuyer)
Storage: Sandisk Solid State Drive 128GB 2.5" Solid State Drive  (£39.98 @ Scan.co.uk)
Video Card: Sapphire Radeon R7 265 2GB Video Card  (£124.63 @ More Computers)
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply  (£34.50 @ Aria PC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  (£67.95 @ Ebuyer)
Total: £530.81
Generated by PCPartPicker 2015-05-27 11:28 BST+0100
https://linustechtips.com/topic/374711-help-with-pc-build/#findComment-5068170
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  (£143.03 @ More Computers)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (£65.96 @ Scan.co.uk)
Video Card: MSI Radeon R9 280X 3GB TWIN FROZR Video Card  (£169.98 @ Ebuyer)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  (£34.92 @ Scan.co.uk)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  (£46.98 @ Scan.co.uk)
Total: £635.95
Generated by PCPartPicker 2015-05-27 11:32 BST+0100
I can't cut corners though.
@WereCat I think you forgot a CPU cooler.
Any unknown button should be pressed even number of times.
https://linustechtips.com/topic/374711-help-with-pc-build/#findComment-5068186
You don't really need an aftermarket cooler for a non k processor, you might need it if your system is running a bit hotter then you want or your ambient temp is quite high.
Steve Wozniak - "Never trust a computer you can't throw out a window."        Carl Sagan - "If you want to make an apple pie from scratch, you must first create the universe."
CPU: Core i5 6600K Cooling: NH-D14 Motherboard: GA-Z170XP-SLI RAM: 8GB Patriot Graphics: Sapphire Nitro R9 380 4G Case: Phanteks Enthoo Pro HDD: 2TB Seagate Barracuda PSU: Threamaltake Smart 750W
My computer runs on MSX, Its very hard to catch.
https://linustechtips.com/topic/374711-help-with-pc-build/#findComment-5068230
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£23.99 @ Novatech)
Memory: Kingston Fury Black Series 8GB (1 x 8GB) DDR3-1600 Memory (£43.17 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£39.97 @ CCL Computers)
Total: £635.95
I didn't. The one comes with CPU is good enough.
https://linustechtips.com/topic/374711-help-with-pc-build/#findComment-5068244
Take h97 if you take locked (non k) processor. And stock cooler is just fine, so you can save a buck or two.
CPU: i7 5820K Motherboard: MSI x99A SLI PLUS RAM: Corsair Vengeance DDR4 2800mHz (4x4gb) GPU: MSI GeForce  GTX 980Ti Case: NZXT S340 Storage: 840 Evo 120gb and WD Blue 1TB  PSU: EVGA SuperNOVA G2 850W CPU Cooler: be quiet! Dark Rock 3
GTX 980 Ti (reference card) High Idle temps solution -
https://linustechtips.com/topic/374711-help-with-pc-build/#findComment-5068301
Why do you guys all pick an i5, an i3 is good enough for LoL, Smite, Cs;Go
And although he mainly talked about those, he also wants to play other games as well.
Currently roaming the forums in boredom
I like mice and keyboards and the sort
Formerly TheFlurryGames
https://linustechtips.com/topic/374711-help-with-pc-build/#findComment-5068326
R9 270 is probably right for you, but you cant get an i5 and an r9 270 with a 500 dollar budget. If youre willing to overclock you should get a g3258. It only has 2 cores though so if you wanna play GTA V you should get a 4 core CPU like the x4 860k. I3 is probably not a good idea because ht can have negative impact on gaming performance.
https://linustechtips.com/topic/374711-help-with-pc-build/#findComment-5068452
Basically I want a gaming PC that can run most games at 50-60fps the main games I will probably play will be like csgo LoL and smite so not very intensive my budget is £550 including windows thank for you help
Can we assume that you mean most games at 1080p Ultra?
The CPU and GPU can be a bit of a hot discussion, but as long as you get a good quality power supply and a half decent motherboard (for a decent upgrade path, like a Z97 board) you should be more or less covered.
GTX 960 is a great card that I personally recommend, but you won't be able to run ALL games at 1080p Ultra (the only game I have to turn the settings down is Crysis 3).
Also, try to cut corners where possible. For example, I got a secondhand case from a friend. It may not cut down the cost massively as a whole, but every little helps.
Just don't cut corners on your PSU.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/374711-help-with-pc-build/#findComment-5068617
