CS:GO shuts down PC randomly on match load
Solved by Mitico,
Its common problem with cs go,even i had it,its about how the game handles memory..you must edit a file in game folder.. as soon i find the fix guide again ill link it here
*EDIT*
Go in steam folder,then steam apps,commons,counter strike and last cfg look for the file called config.cfg and edit cl_disablehtmlmotd from 0 to 1 after saving this find video.txt in same folder and set settings.gpu_mem_level to 1 and settings.mem_level to 0 save everthing and have fun
Featured Topics
CentreMetre ·
Posted in Peripherals0 -
WolfOfValhalla ·
Posted in Graphics Cards6 -
6
10
JezzaKyle ·
Posted in Troubleshooting3 -
7
RanchTheHay005 ·
2
2
3
