I won't tell you the answers, but I will give you some help on some of the questions:
11) The gradient of a perpendicular line is -1÷the gradient of the other line, and the gradient of the other line can be found by doing change in y÷change in x
12) x-y=1÷xy - the minus sign means that it flips to the other side of the fraction
13) Complete the square to find the turning point of the graph
14) Just add and subtract them to find an expression in the form ax2+bx+c
15) y=mx+c. You know y, m and x, so solve it for c
17) Common denomintaor
18) The y axis has the equation x=0
19) Multiply them by something such that you can add them together to cancel one of the letters
HTTP/2 203
https://linustechtips.com/topic/374330-maths-help/#findComment-5063511
I bucked up and did most of them and stopped being lazy. :P
Thanks for the help though.
PEWDIEPIE DONT CROSS THAT BRIDGE
https://linustechtips.com/topic/374330-maths-help/#findComment-5063667
slope of line n is (15-12)/(4-7)= -1
slope of perpendicular line is -1/n = 1
12
Just put negative exponents up or down depending on where they are.
That makes:
9n^7 / 12m^7 p²
13.
P=-25d²+500d
P'=-50d+500
500=50d
d=10
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/374330-maths-help/#findComment-5064638
