Hello guys!
I need some help choosing a good desktop pc case.
I want it to have good airflow and a nice window.
My budget is not more than €80. (I'm going to order it at Alternate.nl)
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/373467-pc-case-help/
could you possible expand a little more, are you going to have any sort of water cooling?. SLI? ATX or mATX or miniITX
My Rig - BloodLust CPU i7 4790k @4.8Ghz - GPU  Duel SLI Gigabyte Geforce GTX Titan X Custom vBios Overclock Motherboard z97 Sabertooth Mark S Limited Edition PSU Corsair HWi 1000W Platinum RAM Avexir 1.1 Blitz 16gb 2400Mhz Storage 2x Seagate 1TB Harddrives SSD Hynix 128GB Case Corsair 900D PcPartPicker - https://uk.pcpartpicker.com/b/pkKZxr
https://linustechtips.com/topic/373467-pc-case-help/#findComment-5051957
whats the current pc specs
and budget
he said its 80 euros
https://linustechtips.com/topic/373467-pc-case-help/#findComment-5051960
https://linustechtips.com/topic/373467-pc-case-help/#findComment-5051970
I don't have a pc yet, I want a single GTX970 and an aircooled i5 4590.
https://linustechtips.com/topic/373467-pc-case-help/#findComment-5052240
Thanks, I think I'm going to build my pc in 8 months, pretty long but yeah :/
https://linustechtips.com/topic/373467-pc-case-help/#findComment-5052252
80 euros for the pc doesnt make sense
He's asking about the case, 80€ for a case makes perfect sense
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/373467-pc-case-help/#findComment-5055792
yes but why should budget for the overall system matter?
80€ was the budget for the case, not the system
My rig:
https://linustechtips.com/topic/373467-pc-case-help/#findComment-5055931
Yes, but he is asking about budget for the system. This guy could really use some punctuation to make what he's saying more clear.
and budget
for the pc
"Rawr XD"
https://linustechtips.com/topic/373467-pc-case-help/#findComment-5055980
wow, i'm fucking dense today.... i'm sorry.
My rig:
https://linustechtips.com/topic/373467-pc-case-help/#findComment-5056023
Dont worry everybody is from time to time :D and yes xDanielxOossiex you should go with the s340 its awsome
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/373467-pc-case-help/#findComment-5056104
lol at least i can admit it.
and yeah, s340 would be a great choice.
My rig:
https://linustechtips.com/topic/373467-pc-case-help/#findComment-5056134
