When I turn on my computer the graphic card doesn't kick on.
Gigabyte R9 270
Msi 970a g43
Amd fx 6300
Please respond quick..
Oh, and it started around 4 today I was watching a YouTube video the I put it on 1080p then it frozen the I turned it off. After when I turn it on there was no connection to my monitor
https://linustechtips.com/topic/372488-help-i-need-somebody-help/
Gigabyte R9 270
Msi 970a g43
Amd fx 6300
Yea what PSU do you have ? What about RAM as well.
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
O
For the psi I have Nzxt 550w and corsair vengeance 8gb 4x2
What do you mean not kick on ? Try to take out the plugs and plug it back it for the GPU.
when i mean kick on. You hear the computer turn on then you hear a small zap near the graphic card and dose nothing
are the fans running ? on the GPU ? if not did you mount it properly to the motherboard?
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
probably your psu...
try the gpu in another pc first tho
i wish i have another gpu but thats my first computer, but i have another computer but its a 2005 computer amd athlon x2 3800+ with mobo with a nvidia graphic card that wont play 720p youtube video xD
plug the gpu into another pc with PCI-E slot and see if it works
if it does...and doesn't crash the pc right away..then its your PSU
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
