HELP ME!
Go to solution Solved by Sam Z Man,
its small. but noticeable, and you can fell them too
she suspects it might be the spay thing the other people were using to stick things...
I would go buy some Plastic razer blades, they will be able to remove the bumps of glue while not damaging the surface.
My mom brought my dads laptop out to paint some walls. She leaves for lunch and comes back, then goes home a few hours later. That night I cleaned the laptop (Mac) and noticed the whole thing got a ruff surface feel. Its not paint, (it looks like super small dots of dark grey on the metal, but its black on the keys, and blends on the screen) I don't know what it is. When I asked her if she knew about this she freaked out and grabbed the mac, and started trying:
iKlear
WD-40
Alcohol
Nothing worked. She's worried af, (my dad isn't really someone you want to get mad).
Pls help me. Your help will be truly be appreciated!! =D
P.S My dads coming home in tomorrow... *_*
https://linustechtips.com/topic/371507-help-me/
iKlear
WD-40
Alcohol
@Xmaxx44X Photo? This happened as a result of you cleaning it right? What did you clean it with?
https://linustechtips.com/topic/371507-help-me/#findComment-5029575
-snip-
Pics?
https://linustechtips.com/topic/371507-help-me/#findComment-5029576
GUYS THIS IS A BIT funny but the dots are too small for my camera... =(
you can quote people did you know? ;)
If they are so small, is it really a problem? It may have been some sort of acid, or something that reacts differently on the metal and the rubber. Ask your mother what substances she may have spilled in its general direction while she was painting.
sudo chmod -R 000 /*
https://linustechtips.com/topic/371507-help-me/#findComment-5029701
https://linustechtips.com/topic/371507-help-me/#findComment-5030118
So... glue? If it is glue, try to determine exactly what sompound that was and look for a compatible solvent. Making sure that it doesn't ALSO dissolve rubber of course.
https://linustechtips.com/topic/371507-help-me/#findComment-5030166
https://linustechtips.com/topic/371507-help-me/#findComment-5030450
