CPU pump noise!
Go to solution Solved by Enderman,
Ok. So its not a defective pump. I was thinking about return it and get a air cooler I am getting tired of have pump issue.
no all AiOs have a bit of air in them
you need to wait for a while until the microbubbles accumulate at one point of the lop and stop going through the pump which is what makes all the noise
mounting the radiator vertically speeds up this process a ton
Two days ago I exchanged my NZXT X61 for Corsair 100i GTX because my X61 had rattling sound on it's pump. Last night I noticed some noise coming from my 100i CPU pump. Its very low noise but sometimes it is audible. Is this ok or my CPU pump defect. https://youtu.be/nm9kSNZY5cI
CPU: Core I7 4790k @4.7Ghz MB: Gigabyte GA-Z97X-Gaming 7 GPU:GTX 980 Ti SLI RAM: Corsair vengeance pro 16GB 2400Mhz Storage: Samsung 850 PRO 512 GB boot drive, WD black 2TB PSU: Corsair HX1000I Display: Samsung UD590D 4K monitor Cooling: Corsair H100I GTX Keyboard: Corsair K70 RGB Mouse: Mionix Naos 7000 Operating System: Windows 8.1
https://linustechtips.com/topic/370585-cpu-pump-noise/
Thats just air inside the loop
you can remove it by mounting your radiator vertically or tilting your case for a few weeks so that the tubing coming out of the radiator is the highest point, then put the case flat when the noise is gone
https://linustechtips.com/topic/370585-cpu-pump-noise/#findComment-5017731
@Enderman put up this video a few days ago. You might have some air in your pump.
Wow I was just going to paste that link...
I got ninja'd with my own content! lol
https://linustechtips.com/topic/370585-cpu-pump-noise/#findComment-5017752
https://linustechtips.com/topic/370585-cpu-pump-noise/#findComment-5017780
https://linustechtips.com/topic/370585-cpu-pump-noise/#findComment-5017793
I see thanks for the Info.
https://linustechtips.com/topic/370585-cpu-pump-noise/#findComment-5017803
