Power supply probably is going bad
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
https://linustechtips.com/topic/370417-please-help/#findComment-5015647
WHAT SHOULD I  UPGRADE TO I HEARD THE GTX 750TI IS A EXCELLENT CARD WITH A CORE I3
PRETTY MUCH AN ENTIRELY NEW SYSTEM WITH 4GB OR MORE OF RAM AN I3 OR OVERCLOCKED G3258, 750 TI REALLY AT THE MINIMUM AND I RECOMMEND A NEW KEYBOARD.
https://linustechtips.com/topic/370417-please-help/#findComment-5015656
MY PC HAS STARTED TO RANDOMLY TURN ON AND OFF IN THE NIGHT ITS SO WIERD WHAT COULD THIS BE ?
PC SPEC:
INTEL CORE 2 DUO @2.8GHZ
NVIDIA GEFORCE 2 MX
500MB RAM
60GB IDE HDD
And that camper parked outside your house? That is my FBI Surveillance vehicle.
https://linustechtips.com/topic/370417-please-help/#findComment-5015674
We need a price range for your build, What you will be doing ect.. IF you wanna build a new one.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/370417-please-help/#findComment-5015680
PC SPEC:
NVIDIA GEFORCE 2 MX
500MB RAM
60GB IDE HDD
it might be a problem with your monitor or the easy way around it
UPGRADE
no offence but seriously this would be a great time to upgrade. only 500mb of ram I'm not mocking you I'm just saying that this is a good time to upgrade.
IF YOU WANT TO. I AM BY NO MEANS TRYING TO FORCE YOU TO UPGRADE AT ALL IT'S JUST A SUGGESTION.
https://linustechtips.com/topic/370417-please-help/#findComment-5017244
yeah but u would be kinda "bottlenecking" the 750Ti so try a i5-4670k for around $250 or go up noch and get i5-4690k for around the same price and get 0.1Ghz improvement and some other things as well, anyways pair any of these with the 750Ti and you're golden but if u need more pay around double the price of the 750Ti and get a power monster a gtx 970 factory oc for around $350 from EVGA. a GTX 970 with i5-4670k/4690k you can run almost any game at medium to high settings at 1440p BUT IF YOU WANT TO GO WITH A CORE i3 AND GTX 750Ti THEN THAT IS ABSOLUTELY FINE AS WELL IT IS YOUR CHOICE.
https://linustechtips.com/topic/370417-please-help/#findComment-5017420
