Hyper 212X vs Seidon 120V vs H60 for 4690K
Solved by Saladin,
For 4690K, 4.5 GHz is expectable?
Depends on the chip you have. For example on one 3570k I can get 4.65 GHz and on another it tops out at 4.3. Just depends on the chip. You have to play around with the multiplier and the voltages and find out what is stable. That being said 4.5 isnt unusual and is a good target to shoot for, a hyper 212 will be able to handle the temps from an overclock at that level assuming your chip can achieve it (keep it under 1.35 volts, the lower the better).
