Used watercooling parts
Solved by W-L,
-SNIP-
All those things can be disassembled and cleaned fairly easily the main thing is the pump, those do have a certain lifespan on them, you want to make sure it's not making any noises and that it has never been run dry it will destroy the ceramic bearing if it has for any short period of time.
Also if he used a colored coolant it tends to stain blocks and acrylic, not to mention get trapped in the rad so that may be something to look out for.
