It's there newest one .Just came out end of June..It does what it's supposed to do and that's all I care about.. Plus the colored leds are kinda cool..
I really like it, I just wish there was a way I could see the fan rpm's aswell, but then again I guess I'd get used to where the "levers" needed to be for gaming/ silence/ etc.
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-473747
would something like this fit your needs? it is designed for both air and water.
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_48&products_id=20837
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-473791
You kids and your fancy controllers.
Ha, I don't even own one, I was looking at the t-balancers for my next upgrade.
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-474049
In response to all the NZXT reccomendations.I'm not a big fan of the NZXT controllers. Maybe the new ones are different, but I've had a couple and they (and no, it wasn't the fans) whined pretty bad if it was anything but 100% or the minimum of 40%. They worked, but they whined.
Plus, the minimum of 40% was annoying. But most lower-cost controllers have that.
As for a recommendation, I'd go with the Fractal Design Adjust 108. It looks amazing, has 36 watts per channel,and excellent build quality.
CPU-AMD FX 8350 @ 4.9Ghz | GPU-Sapphire 7970 OC | Motherboard-AsRock Extreme9 990fx | RAM-8GB Mushkin Blackline Ridgeback
Case-NZXT Switch 810 | Heatsink-NZXT HAVIK | SSD-Samsung 840 250GB | HDD-Seagate Barricuda 1TB; WD Green 2TB
PSU-Seasonic X-Series 850 Watt | Mouse-Razer Naga | Keyboard-Razer Blackwidow | Speakers-Logitech z623
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-474059
If you want manual fan controll go for something like the bitfenix hydra or the fractal adjust 108 and use splitters, both have enough wattage to power all of the fans. if you want automatic the t-balancer bigNG is good but a pain in the a*se to setup. i believe aquaero makes a good automatic fan controller aswell.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-474080
OMG I like that one...
Motherboard: MSI-990FXA-GD65 | CPU: AMD FX-8350 @ 4.3Ghz | CPU Cooler: Corsair H100 | RAM: 8GB Corsair Vengeance 1600Mhz | GPU: MSI GTX 770 Lightning @ 1300Mhz CC and 8000Mhz MC | Case: Fractal Design ARC Midi R2 | PSU: Corsair AX850 | OS: Windows 8.1
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-474347
Ive a Scythe Kazer master 2, looks goooood
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-474386
I'd recommend the Scythe Kaze Q-12. It supports 12 fans.
Do you know where I can buy the black one? Newegg says its discontinued :3
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-511889
I presume your're from the US, in which case I really don't know where you could find one. Here in Finland they are available almost everywhere.
Lame.......... I like it a lot too, and it's brushed aluminum so it'll match my 900D.. :(  I may have to get the fractal design adjust 108 instead. I can buy it from scythe's website but idk how much shipping would be since it's from EU I think, and I don't see where the option is to get silver or black so idk.
Edit: here's the site but it won't open anything when I click buy now http://www.scythe-usa.com/product/Fan%20con/001/ScytheUSA-ProductsKQ01-5.25.html#
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-512206
Ever thought about running them over a Fan Splitter and connecting this fan splitter to a fan controller? I gotta be honest, I don't know if this would work, but the first that came to my mind. They're actually fairly cheap, there are options from Phobya, Swiftech and Bitspower.
phanteks enthoo pro | intel i5 4690k | noctua nh-d14 | msi z97 gaming 5 | 16gb crucial ballistix tactical | msi gtx970 4G OC  | adata sp900
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-512241
I still need a fan controller then lol.
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-512257
Yes, but you could save some money, as you don't need some Uber - Fan Controller with 9001 Channels with 12 Gigawats per Channel (Note: Reply contains sarcasm)
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-512263
Can you link me the sites if there are any? I just looked at every single US site and like 10 UK sites, all are discontinued :/
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-512264
the controller I was looking at is only 30$ lol
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-512266
That Adjust 108? Yeah, that would be something I would recommend. If you're looking for a touchscreen than the Lamptron FC Touch, offers 30W per Channel as well
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-512282
Yeah the adjust 108 has 36watts per channel and has 6 channels, by channels they mean it can do 6 fans? But if I y split each one I can do 12 fans in theory? If so I may do that because.. I think I'll have something like.... 4 on rad #1 4 on rad #2 and probably 4 other fans for intake/exhaust. So I'll need to be able to control 12. I wish it'd say on the adjust 108 if there was an option to turn the fans off all together, but it doesn't  :9
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-512289
Yeah the adjust 108 has 36watts per channel and has 6 channels, does that mean it can do 6 fans? But if I y split each one I can do 12 fans in theory? If so I may do that because.. I think I'll have something like.... 4 on rad #1 4 on rad #2 and probably 4 other fans for intake/exhaust. So I'll need to be able to control 12. I wish it'd say on the adjust 108 if there was an option to turn the fans off all together, but it doesn't  :9
Yeah, that would be absolutly possible, especially because it has such a high wattage support.
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-512301
LOL OK I go to like 15 diff sites and it says fractal design discontinued the 108.......................................... Why are you doing this to me :(
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-512306
Found 2 sites that sell it, heatsink factory and "comet supply" I've never heard of comet supply but its cheaper there by 10$ so I guess I'll buy it lol
inb4 scam
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-512320
Yeah, I could've told you that before :D
Again, the FC Touch maybe the choice for you then. 30 Watts are still plenty to run 2 fans on one header.
http://www.mountainmods.com/lamptron-fct-touch-fan-controller-black-p-622.html
Plus, I think it just looks bloody sexy!
https://linustechtips.com/topic/36812-best-fan-controller/page/2/#findComment-512327
