I think I'll be getting a fan controller with my new 900D for when I do my watercooling build, I'm going to have something like.... 13 fans or something like that.  Majority will be noctua nf-f12's. (hopefully the black versions if they're released soon)
Cost isn't an issue, so shoot away
https://linustechtips.com/topic/36812-best-fan-controller/
bitfenix one is my fav.
the recon?
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-472727
yes.
I like that and the sentry 2 by nzxt, but unsure which I'll go with, I'm gonna keep looking around and see what other options there is before I make my decision XD
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-472753
Lamptron or Sunbeam Rheobus (whatever the thing was called, just google it)
Is this the lamptron? http://www.lamptron.com/product/controllers/cw611/
the sunbeam looks sorta cheap, plus no LCD readout, which I really like
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-472791
I got a NZXT sentry mix 2 and I love it.. Those ones with lcd screens are known to lose the display at around a year.. Plus I don't want to run temp probes all over my case..
I guess you're right but idk, I really love the look of the LCD, but running probes everywhere would be so annoying, not to mention I wouldn't even know where to put them lol
I understand near the gpu/cpu but.. am I suppose to stick it right next to the cpu.. or gpu.. or what lol
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-472819
Some people put them in the heat sink fins.. Still there's like 5 or 6 probes to run.. Also you can't see most the screens on those unless you look head on..To me they sounded like a pain..I almost bought the white recon but I read a bunch of people's screens dying and then the could not control anything anymore.. So I went with the one I have. It has 6 different channels with 30 watts per channel and you can select 6 different colors for the less one the front.. So it looks more plain to me..
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-472834
nothing touches a aquaero
Is there a specific one I should look at? Or are they all basically the same? Their site is kinda low-end looking
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-472836
You got a point, where would I put the probes after watercooling though? since I wouldnt have heatsink fins :s
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-472841
I have the recon. You can plug it in by usb and control it by software.
FX8120 @ 5.0GHz | Sabertooth 990FX | Patriot Viper Xtreme 8GB @ 2133MHz | Powercolor HD7950 @ 1300/1800 | Bitfenix Shinobi XL Modded | Corsair AX850 | Mushkin 120GB & Seagate 2TB | Bitfenix Recon | 5X SP120 PE | 6X Yate Loon 120mm HS
Koolance 200 Res | 2X Koolance 360 Rads | Danger Den CPX Pro | EK 7950 Block | Koolance CPU Block | Bitspower & XSPC Fittings
Green Machine
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-472855
they are all capable of the same thing, if you don't need a display get the LT version.
So you judge one of the best watercooling companies by the looks of their site :D ?
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-472857
if they're one of the best watercooling companies why does it look like a 4 year old made their site lol
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-472881
http://www.newegg.com/Product/Product.aspx?Item=N82E16811995016
This one is the only fan controller I recommend. 6 Channels and 30w per channel. I prefer dials and switches because touch screen can fail over time. Also when looking for a fan controller, consider how many fans and what fans they are.
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-473016
FX 6300 - MSI 7870 Ghz - M5A97 R2.0 - Team Vulcan 8GB - WD Caviar Blue 1TB - Rosewill HIVE 550w - NZXT Source 210 (white) - Loud Fans
Peripherals - Logitech G105 - Cobra mouse - Acer G236HL - Logitech desktop mic - Logitech LS21 - Audio Technica ATH-M30
Laptop - Acer Aspire V3 - A84500m - 7670m - 15.6" screen (1366x768) - 3.5GB DDR3  - 500GB Scorpio Blue
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-473151
Might not be what your looking for but corsair link?
Corsair link only works with things plugged into the block I believe, so when I build a custom loop my h100i will be getting sold/put back in it's box.
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-473304
I have the Sentry mesh controller and it is awesome for something that is just five slide switches.
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-473374
it still works for 4 pin fans right? o.O
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-473377
Yes..Well at least it says that it does..They are 4 pin fan connectors coming off controller..
o all the other controllers i looked like they only had 3 pin
https://linustechtips.com/topic/36812-best-fan-controller/#findComment-473613
