So, I think that I f*cked up my pc
I was trying to download Sony Vegas Pro 12 32 bit using torrent.( I know, pirating is bad. Shame on me)
So, I found a litle bit harder a 32 bit version but I did. It had everything. The installer, the keygen, installation guide. Everything
So, I double clicked on it but it didn't happen anything. After 3-4 seconds the mouse looked like something was working. As I saw that, being a litle suspicious I opened task manager to see the running proceses and in the meantime some windows appeared and dissapeared quickly on the screen. I couldn't find anything suspicious in the task manager, the only thing that I saw it was that I couldn't find any sonivegas.exe process
Then some icons started appearing on the screen. Now I got really impatient. 3 shortcuts appeared on the screen. Driver scanner, Speed Up my pc, and another one which I don't remember. I found 1 process in the task manager and shut it down and uninstalled the programs whitout opening any, except of speed up my pc which I opened accidentaly but I closed within seconds.
After that, I calmed down and tried to download another torrent but then I found the big problem.(I use chrome). I couldn't download anything. It started downloading but when it was completed it said that the antivirus couldn't scan the file which is weird because I don't use any antivirus program. I tried restarting my pc thinking that this would resolve the problem but it's worse. I can't access any site. It tells me that the security certificate has been cancelled, that I might be communicating with an attacker.
I tried using IE but I can't download anything because everything looks like it's getting deleted when it's complete( I tried to run the program, not to save it, but it didn't work either)
Please, I know it's a lot to read but i'm desperate. Right now I'm trying to download an antivirus with my phone and then to copy it on the pc but I don't know if it will work.
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/36776-i-need-urgent-help-please/
Don't forget to try out Malwarebytes. Secondly, open Resource Manager and check what's downloading and uploading data and look for anything that you don't recognize.
Note: I do not condone piracy or anything illegal. Delete any files that you may have obtained illegally or that are illegal for you to have.
https://linustechtips.com/topic/36776-i-need-urgent-help-please/#findComment-472119
Ok, first of all i think you are a victim of malware, second the three programs that got installed are usaully sponsors of many free softwares (they usually tell you if you want to install them), BUY a proper antivirus and scann you computer.
https://linustechtips.com/topic/36776-i-need-urgent-help-please/#findComment-472121
Ok, so I tried System Restore which actually installed the programs back
https://linustechtips.com/topic/36776-i-need-urgent-help-please/#findComment-472153
No antivirus will help you now.Stop the pc,re-install the windows(re-format any hard disk you have) and you are done.You can use a program like data recovery(trust me it works i recovered some music and pictures from a drive after i re-installed the windows) and that's it next time don't use torrents from any sites.
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/36776-i-need-urgent-help-please/#findComment-472157
This is against the CoC
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/36776-i-need-urgent-help-please/#findComment-472159
People shouldn't be helping someone who doesn't pay for their products. If you're going to pirate do it with at least some knowledge before hand so you know what and what not to download. Illegal downloads are your problem, you download a virus don't come to a forum and expect any help unless the forum is about pirating in the first place.
System Specs:
CPU: Ryzen 7 5800X
GPU: Radeon RX 7900 XT
RAM: 32GB 3600MHz
HDD: 1TB Sabrent NVMe -  WD 1TB Black - WD 2TB Green -  WD 4TB Blue
MB: Gigabyte  B550 Gaming X- RGB Disabled
PSU: Corsair RM850x 80 Plus Gold
Case: BeQuiet! Silent Base 801 Black
Cooler: Noctua NH-DH15
https://linustechtips.com/topic/36776-i-need-urgent-help-please/#findComment-472185
All things being said against the CoC - not sure what version of Windows you are using, but reboot - and just before the Starting Windows comes up, start hitting F8 - should get the boot menu. Start Windows in Safe Mode with networking.
Should then be able to install the following and run - Malewarebytes and SuperAntiSpyware. Run one, remove what it finds, reboot back into safe mode, run other. Rinse and repeat. Keep doing this till they both find nothing.
Now - go to www.eset.com and run the online scanner. Finally, download and run ComboFix.
All these, should clean out your system.
And BTW - don't pirate... enough said...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/36776-i-need-urgent-help-please/#findComment-472651
