My new Asus Strix GTX 970 ramps up to 100% randomly and goes down again. Some times it lasts up to 5 min and its pretty loud. Anything i can do to fix this?
CPU: Intel Core i7 4790K
CPU Cooler: Noctua NH-D15
RAM: Corsair Vengeance Pro 16GB 1866MHz
GPU: Asus Strix RTX 2060 OC
Motherboard: Asus Maximus VII Hero
Storage: 1TB, 500GB, 250GB SSD's, 1TB SSHD
Case: Corsair Carbide Air 540
https://linustechtips.com/topic/367703-gpu-fan-goes-to-100-randomly/
I have been seeing lots of problems with people that have Titan x's doing this, wondering what the issue is.
Are you sure it's not just the fans going from off to on, from the "0 db" feature?
I can see the fans going from 0 to 3000 RPM in HWMonitor and its really loud.
Hmm..
Do you use afterburner? Could you take a picture of it perhaps?
Hmm..
haven't installed any gpu software other than drivers.
Is temperatures abnormal?
nope temps are good
I'd say make your own fan curve, since you have a strix you can make one like this:
If your fan curve that's built into your BIOS is messed up somehow, this should fix it.
ok thanks!
