So i was studying 2 days in a row and i have to study more for the exams but today i can't seem to be able to focus on studying, tried this morning but after 20 mins i started getting a huge headache or being hyperactive and not being able to sit down and study.
Exams start on monday any help? Had the PC turned off till 1 hour ago.
https://linustechtips.com/topic/367635-studying-help/
its called concentration limit, it's diffrent for each person, i recommand to take a break and relax a few hours, stressing yourself out and focussing too much on the stuff won't do much good. if you study too much it's sometimes better to haven't studied at all or a bit less.
May the light have your back and your ISO low.
https://linustechtips.com/topic/367635-studying-help/#findComment-4977426
I think that anxiety plays a big role at this as well.
2 lessons per day every day for 2 weeks.
https://linustechtips.com/topic/367635-studying-help/#findComment-4977433
Stop being on here! no seriously just chill dont do anything with your pc phone or tablet but them somewhere you cant reach them it might be boring at first but then...
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/367635-studying-help/#findComment-4977474
Hmm. WIll try that again thanks!
https://linustechtips.com/topic/367635-studying-help/#findComment-4977482
Been happening to me a lot in last year or so, just take a break, go out on fresh air, take a walk or something. Just get away from anything that involves using your eyes and head (phone/pc/tv etc.)
The ability to google properly is a skill of its own.
https://linustechtips.com/topic/367635-studying-help/#findComment-4977785
Go out for a run or a long walk. I've noticed that it helps a lot
https://linustechtips.com/topic/367635-studying-help/#findComment-4977797
Doodle ... It helps the mind ease off while not having the need to use the Internet ... You can jog as well ... Relax ...
... Life is a game and the checkpoints are your birthday , you will face challenges where you may not get rewarded afterwords but those are the challenges that help you improve yourself . Always live for tomorrow because you may never know when your game will be over ... I'm totally not going insane in anyway , shape or form ... I just have broken English and an open mind ...
https://linustechtips.com/topic/367635-studying-help/#findComment-4978504
