Is my GPU and CPU good enough for oculus rift?
HawkJ
Hello everybody. The recommended specs for the oculus rift was released, so i was wondering if my PC Specs come under the recommended specs or whether i should go for an upgrade.
My PC Specs
CPU: i7 4770k
GPU: Asus GTX 780Ti DC2OC
Ram: 8 Gb
And the oculus recommended specs are:
NVIDIA GTX 970 / AMD 290 equivalent or greater
Intel i5-4590 equivalent or greater
8GB+ RAM
What do you guys think?
Yeah, It will run just fine.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
You're above the recommended specs in both respects.
4K // R5 3600 // RTX2080Ti
It recommends a 970 or an equivalent card and a 780ti is just as good or even better.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
No problem, should run fine!
They meet the recommendations but then again recommendations are usually lower then what you need to use it comfortably.
780Ti WAY outperforms on cuda, has 1GB less ram. It will more than likely be okay
Those are recommended, not minimum. A 780ti is still a beast of a card- it will run no problem.
Oh Perfect. Thanks a lot. The reason is that i want everything to run smoothly. If not then i was planning to go for maybe a 980Ti or a Titan X
4770k is fine. 780ti may not have the full software support. idk
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
Yeah, i am confused as well in the case of the GPU. 780Ti has more cuda cores than 970 but it was from the last generation
