Replacement for Mionix Naos 7000
Solved by Alayer,
If Massdrop is an option for you, they are having a drop on the Naos 7000 currently (-50%).
When it comes to similar mice, nothing really comes close to the Naos in terms of sensor, so you'd have to sacrifice a bit there if you went with other Naos mice, Func MS-3 or Qpad offerings.
ERMAGERD.
Thank you. I'll get on that ASAP!
Featured Topics
Bobzcpu ·
Posted in Power Supplies1 -
1
RZBAKA ·
Posted in New Builds and Planning4 -
Magnumenforce ·
Posted in Phones and Tablets2 -
1
Crash The Noise ·
Posted in Programs, Apps and Websites3 -
5
