GTA V slutter/lag help
Go to solution Solved by Aniallation,
R9 280 not x
Did you update to the latest Catalyst 15.4 Beta drivers? They make a huge difference
Specs?
CPU:AMD FX-8350 @ 4.4 Ghz  - Motherboard:Gigabyte GA-990FXA-UD3 - RAM:Kingston Hyper X Blu - 8GB - GPU:Gigabyte GTX 760 - Case:NZXT H440 Red & Black - SSD:Kingston Digital 120GB - HDD:(2) Western Digital 1TB Blue - PSU:Thermaltake Smart 650W 80 PLUS Bronze - Keyboard:Corsair Vengeance K95 RGB - Mouse:Corsair M45
https://linustechtips.com/topic/366012-gta-v-slutterlag-help/#findComment-4957665
well this is why i put them in my profile but :
FX-4130 ( is going to get changed because its amd..)
R9 280 not x
8 Gigs of ram 1600mh
win8.1 pro
Don't bother putting, it there, it's more convenient for people if you include it in the post
https://linustechtips.com/topic/366012-gta-v-slutterlag-help/#findComment-4957820
I have the same problem. Usually it happens in multiplayer because there is some bug thing that makes you cpu run at 100% because it makes you the host of the server or something (might be wrong) so therefore you cpu is causing the drops. I have a i5 and i have the exact problem. Im hoping gta can fix this though.
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
https://linustechtips.com/topic/366012-gta-v-slutterlag-help/#findComment-4958321
it was the drivers lol. But still that might be usefull because i haven't really played multi
I didn't know what to put here...
https://linustechtips.com/topic/366012-gta-v-slutterlag-help/#findComment-4961238
