Motherboard difference
Solved by Captain Matt,
What do you mean by better performance?
Motherboards don't make any measurable difference in fps.
The things to look for in motherboards are:
quality electrical components, pci slot layout, bios layout, number of what types of ports
Consider what you will actually use on the motherboard. Yeah the Gaming 5 has 3 full size pcie ports, but will you ever do 3 way sli or populate all those slots?
Do you stream? The Gaming 5 has the streamcaster thing.
Gaming 5 is looking a little more feature-ful to me.
Beginners guide to motherboards: https://www.youtube.com/watch?v=ZnaQyGAg8Eg
In depth review Krait:
In depth review Gaming 5: https://www.youtube.com/watch?v=Y1NbupbQ83g
Hope it helps!
-Matt
