Hey guys!
For the past few minutes, I have realised that F@h has not been using 100% of my CPU, like it has done before. Heres a photo of my CPU usage on gadgets.
Ignore the first 10% of the graph or so, I had it on Idle for a while.
Basically its just spiking up and down a little, dipping from 65-100% CPU usage. It also seems funny that at 100% usage it hovers around 69-71 Deg C, However during this period of time (spiking) it can go up as high as 75 Deg C.
Also, my GPU is on a higher temperature than before. Usually its doing 71-72 Deg C, But now its doing 76.
My PPD has also dropped by a lot. Previously it was displaying about 200k PPD (Even with pauses inbetween, doing gaming). However today, its only displaying about 50k PPD and is still dropping  (I have it on for 8 hours constant today now). EDIT: Its hovering around 50-70k PPD.
Trying to troubleshoot, My CPU has just taken on a new WU. Is there anyway to delete this WU to take on another WU?
Also, should I be giving my computer some rest? I don't think my computer likes constant load (Never had anything going on constantly for >3-4 Hours before)
Thanks for the feedback!
Quote me if you want me to see your message. Like my post if it helped. Click "Show More" to see things that I use.
Desktop (2014): CPU: Intel Core i5 4690k @ 3.50GHz | GPU: MSi GTX 970 Gaming 4G | Motherboard: MSi Z97 Gaming 5 | RAM: 2x4GB G.Skill RipJaws X 1600MHz + 2x4GB HyperX Black 1600MHz | SSD: Samsung 750 Evo 120GB | HDD: WD Black 1TB | Cooler: Cooler Master Hyper 212x | PSU: Corsair VS650 | Case: Cooler Master Elite 431 Plus | OS: Windows 10 Home
Laptop (2017): Model: Asus UX310U
Peripherals: Monitor: Samsung S24D300 OC@75Hz + Viewsonic XG2401 (144Hz) | Mouse: Logitech G305 | Keyboard: Razer Blackwidow Chroma V2 | Headset: HyperX Cloud Core | Speakers: Logitech Z333 | Additional: Logitech G29
Mobiles: Samsung Pixon (2010-2012) | Samsung Galaxy Ace (2012-2013) | Samsung Galaxy S3 (2013-2016) | Samsung Note 4 (2015)(Lost) | Samsung Galaxy S7 (2016-2019) | Samsung Galaxy S10 (2019 - Current) | Additional: ASUS Zenwatch 2 (2016)
I would verify that the gadget is correct by using
Real temp Gt for the CPU
and GPU-z for the GPU
Check for process that you have running some thing might
be none responsive also try setting fan curves in Msi after burner
If none of these help physically inspect the card and Cpu cooler
check for damage and try re applying thermal past see if that solves the problem
also if you can try the components on another system to help rule out things that may cause this
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
-Have verified that the gadgets are correct to a certain extent CPU: +-1Deg, refreshing rate etc GPU: Smack on.
Some of your cpu goes to supporting the gpu, so its norml.
  While checking processes, I realised that FahCore17 is gone. It was previously using about 15% of my CPU (Like what @iamdarkyoshi said, supporting the GPU). However, searching around, I find a FahCore15, Literally doing nothing at all. Seriously, not even 0.2%.
Checking in Advanced Control, I see my GPU now using Core15. Probably not as efficient as Core17, as my PPD has dropped from about 60-80k Estimated Points to now about 14k. Anyway to force the chance back to Core17? Restart my computer?
That's called "core 15" and "core 17" WUs.
-Core 17 uses 1 full CPU core, while using the GPU as a co-processor. As a result, CPU utilization goes higher, while GPU drops, thus lowering GPU temps. Also core 17 units receive the QRB bonus; as such, PPD (on a gtx 970) hovers around 200~240k.
-Core 15 is completely different. It does EVERYTHING on the GPU, with almost no need for CPU. So you can expect huge drops in CPU usage, as it's... well, not being used! And huge ups in GPU temps, as it's being constantly utilized on 99~100%. Also, they don't receive the QRB bonus, and PPD hovers around 50~70k for such WUs.
Any user with an Nvidia card get's a mix of both WUs. You were just (un)lucky to be monitoring things when working on core 15, or you're just getting really unlucky with getting a lot of Core 15 lately.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
-snips-
Oh wow, thanks for the information! Is it possible to force my computer to only get core17 WUs? Or delete away the Core15 WUs?
No. The folding software is a jerk: you only do what they tell you to do, and you only stop when they want! You can't chose to receive only one type of WU, nor can you abort current ones to try and get new. And if you try being even more of a "jerk" (it's my hardware, why can't I control it!?) by uninstall + reinstall the software to get new WUs, or removing + readding the GPU slots, they punish you for you failed WUs, and you lose the QRB! Way to go F@H, way to go.....
At any rate, the Core 15 WUs still have to be done, whether we like it or not. If researches didn't need such results, you can bet your wallet that they wouldn't bother releasing them.
... to get new WUs, or removing + readding the GPU slots, they punish you for you failed WUs, and you lose the QRB!
Technically, you only lose QRBs when you return less than 80% of your work, is that true?
That means, you can afford to lose 1 in 5 WUs?
You can do 4 WUs in the chrome extention (~5 mins each) and then afford to delete 1 Core15 WU. Is that possible?
Quoting form Bruce:
There are several reasons why you can have your bonus status revoked. The 80% rule is one of them. Bonuses are NOT awarded to people who fail to return the WUs which are assigned to them. The 20% tolerance should be sufficient to cover an occasional WU over which you have no control.
  • 2 weeks later...
There are no QRB for Chrome WU's and they are calculated on different systems. Completing 10 Chrome WU's won't qualify you for CPU or GPU QRB's and those stats at maintaining 80%...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
