Hi there ! :P
I have Mobo: P8Z77-M Pro..
I want to add another GTX 970 and make 2-way SLI...
but i dont think both GTX 970 windforce will fit,well I think the slots r too close to each other in order to actually place another GTX970 Windforce.. there should be a small gap between 2 gpus right? if any1 can help me calculate if 2 GTX970s can fit, ill be happy...
B4 im buying another GTX970...
And sorry for my bad english :P
Sorry if this post is not in the correct topic, don't know where to put it, Gpus or Mobos..
Thank you guys! :D  :)
https://linustechtips.com/topic/363881-will-it-fit-p/
windforce has no backplate so it should be fine.
https://linustechtips.com/topic/363881-will-it-fit-p/#findComment-4929647
the mobo have 3 PCIE slots... can i place one at the first slot and the other one at the last slot?... will it be ok? or it wont work?
the GTX970 im talking about is this - http://www.tomshardware.co.uk/nvidia-geforce-gtx-980-970-maxwell,review-33038-5.html
https://linustechtips.com/topic/363881-will-it-fit-p/#findComment-4929658
Oh wait. I didn't see the last slot :lol:
If the case has 5 or more expansion slots it should be just fine :D
"an obvious supporter of privacy"
https://linustechtips.com/topic/363881-will-it-fit-p/#findComment-4929687
