Okay so I have started playing split screen with my girlfriend but of course console has always supported it more often so I was thinking of like emulating mario kart or something but how would I do that split screen with 2 xbox 360 controllers?
Also there was a program someone suggested that is like a huge programs for loads of emulators and organised them, what is it?
https://linustechtips.com/topic/361082-split-screen-emulators/
n64- project 64
gamecube/wii - dolphin
There are 10 types of people in the world: those who understand binary numbers and those who don’t
bulgara, oh nono
Multipass
https://linustechtips.com/topic/361082-split-screen-emulators/#findComment-4895039
Dolphin has a pretty comprehensive game pad config utility, it's pretty easy to set up.
https://linustechtips.com/topic/361082-split-screen-emulators/#findComment-4895132
me and the Mrs play mario kart wii splitscreen on dolphin with no problems. You can play with 4 controllers.
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
https://linustechtips.com/topic/361082-split-screen-emulators/#findComment-4896696
thanks :D
Can I definitely play with xbox controllers?
https://linustechtips.com/topic/361082-split-screen-emulators/#findComment-4897959
thanks :D
As long as they are wired or as long as you have the wireless dongle for them.
bulgara, oh nono
Multipass
https://linustechtips.com/topic/361082-split-screen-emulators/#findComment-4899182
I've successfully used my Xbox One controller (which everything detects as a 360 controller) with both Project64 and Dolphin. I haven't tried split-screen but I don't see why it would suddenly stop working there.
https://linustechtips.com/topic/361082-split-screen-emulators/#findComment-4899355
thanks :D
Yes sir.
I uses 1 xbox one wires controller and 3 xbox 360 wired controllers.
It's a blast dude, smash bros brawls is sweet to.
As fas as i know evey console that supports splitscreen that can be emulated will also support splitscreen on pc :)
https://linustechtips.com/topic/361082-split-screen-emulators/#findComment-4900681
  • 5 months later...
i cant get my xbox one controller to work properly with project 64 :/
askdjfasdf
https://linustechtips.com/topic/361082-split-screen-emulators/#findComment-6436383
