MSI Lightning VS Sapphire Tri-X 290X
Aleppi
I am choosing between a Lightning and a Tri-X to crossfire with my current 290X. The difference is exactly 60 dollars and I am wondering if the lightning is worth it. BTW the lightning also has a backplate.
i7 4770k/Asus GTX 1080 TI/Asus RX5500 XT/Corsair Vengeance Pro 16GB/Samsung 840 Pro 256GB/Seagate Barracuda 3TB/AX860i/ASUS Z87 PRO/Fractal Design Define R4/HD 598
If you ever plan on watercooling the lightning, it'll walk all over the tri-x.
Also the lightning will run cooler and should overclock better on the "stock" cooler. It's also a bit quieter most likely.
At the moment im not planning on watercooling. I will also have to wait with overcloking as my reference 290x probably would overheat.
Sapphire tri-x is the best value for money, best performing is the vapour x. You can't go wrong with sapphire.
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
LIGHTNINGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG
It is a MUCH better card. Ask @Vexzarium he owns one and he claims it outperforms every 970 that challenges it.
Also, it's $830 in Australia. ($610 USD) so that's pretty self explanatory...
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
Why do you think the vapor x is the best? The lightning is binned and built better.
(just curious, not trying to start a fight or anything)
The MSI Lightning will overclock like no tomorrow from seeing others overclocks it does very well if you are into that.
Thanks for the replies guys. I have decided im going with the lightning.
There's only two 290Xs worth buying imo.
The MSI lightning and the Sapphire Vapor-X.
Awesome choice, you will not regret it. This thing runs cool & quiet. Mine averages around 55-60c max while gaming. That is with a light OC on it, +25 Power/1100mhz/6000mhz.
My highest temp of all time is 72c, which was during Heaven Benchmark, and that had a much higher OC on it. ;) See photo:
post-211843-0-55670000-1430818879_thumb.
CPU: Intel i5-4690k                                                               RAM: 16gb Corsair Vengance Pro DDR3-2400        Case: NZXT S340
Cooler: CM Hyper 212 Evo                                                  Storage: Intel 730 SSD        PSU: EVGA 850G2
Mobo: Asus Z97-A 3.1                                                          GPU: 980ti G1        OS: Windows 10 Pro
