i7 / capture card
Jedicake
Is a capture card completely unnecessary if I have an i7 (and only stream PC games)?
Enthoo Primo - ASUS Maximus Formula VII - 4790k 4.8ghz 1.28v - EK Supremacy Evo Clean - 16GB Crucial Ballistix Tactical - 1000w EVGA Supernova Gold - 2x Alphacool Monsta Rads in push/pull - 2x Galaxy 780 HoF with EK waterblock
Build Log http://imgur.com/a/UV6Wh Just want to warn everyone, my build log is pretty mediocre.
it will get you better performance no doubt depends if that card encodes though if it doesnt no
yes 100% unnecesary
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
yes 100% unnecesary
I had a feeling....
Cause capture cards are just 720p/60fps at best, right? My i7 can handle pretty much any game. My only limiting factor is my upload speed (for streaming I mean)
I had a feeling....
No, some of them can do 1080p 60fps, hell, some high end ones can even do 4K 60fps. (Ofc those are professional ones that cost huge amounts of money, but they are still capture cards.)
I'd say try with your i7, if you find issues, then perhaps go for a capture card, or if you have an nvidia gpu, try using shadowplay.
no need for capture cards
Don't need one especially with hyper-threading. You won't gain much FPS if at all.
This, I tried it with avermedia capture card and using game capture in obs. Not much performance changes. Like it's pretty negligible. If your computer was ass, you would see a difference for sure. (On phone so I'm struggling to link you the thread with what I tested.)
But ya up load speeds can be a pain.
Also OP, there is a capture card that is pretty baller, Magewell I believe its called. Check it out if you wanna see a capture card that goes over 1080p and good frames.
- Fresher than a fruit salad.
