Title says all
My PC Specs: CPU: Core i5 4590 @ stock speeds, GPU: RX 480 8GB, RAM: 16GB DDR3 @1600mhz
Case: Zalman ZM-T4,Motherboard: GigaByte GA-H81M-S2H LGA 1150, HDD/SSD: 2TB Seagate Expansion drive, 1TB Samsung Portable HDD, 160gb Intel SSD, PSU: 550w corsair cxm
:lol:  :lol:  :lol:  :lol:  :lol:  :lol:
https://linustechtips.com/topic/358786-what-is-power-limit-for-overclocking-gpu/
max watts that your card will draw before it starts throttling
just push it up to max so theres the least chance of power throttling
The power limit would be as much as your 6 or 8 pin power connectors combined will push out. I don't know the wattages for these connectors though. Or it could be your power supply, with not enough watts to feed the system, and the gpu and cpu would throttle to avoid overloading the power supply.
FairladyZ | If you want to reply to me, please quote my post! Idiocity, the best money wasting PC build ever!
Is it safe?
Is it safe?
i would say it is. i have mine on max power 122%
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Is it safe?
yes, its limited to 100something percent for no risk of damage
