General Question on Electronic viewfinders.
Go to solution Solved by ShadowCaptain,
So, I was looking around the interwebs about stuff and I saw an article saying if you use the EVF, it consumes less battery and live view is turned off for mirrorless cameras, is this true for all mirrorless cameras? Just was curious.
The EVF consumes less power than the rear display but not by much - liveview is on constantly for mirrorless cameras, if you turned off live view, you would have no viewfinder lol
Computer Specifications:
AMD Ryzen 5 3600  Gigabyte B550M Aorus Elite | ADATA XPG SPECTRIX D50 32 GB 3600 MHz | Asus RTX 3060 KO Edition CoolerMaster Silencio S400 Klevv Cras C700 M.2 SSD 256GB
1TB Crucial MX500 | 1 TB SanDisk SSD Corsair RM650W
Camera Equipment:
Camera Bodies:
Olympus Pen-F Panasonic GH3 (Retired)
Lenses:
Sigma 30mm F1.4 | Sigma 16mm F1.4 | Sigma 19mm F2.8 | Laowa 17mm F1.8 | Olympus 45mm F1.8
Hmm, ok thanks for the reply, was just wondering since the screen is turned off when I use my EVF
Camera Equipment:
Camera Bodies:
Lenses:
but the EVF is just another screen so its just replacing one screen with another
initally you are using a smaller screen say 2cm or whatever instead of 3 inch, so there's abit of battery saving, my guess is about 10% savings in power
