Hey I'm just wondering should I get a 1tb WD black HDD or 2tb WD black HHD? I don't want to waste extra money to get more storage that I'm not gonna use. I don't store any music or pictures and I'm just wondering does a lot of games take up a lot of spaces? I planning on getting bf4 and gta5 and witcher hunt 3 and far cry4 and would they take up more than 500gb of the HHD?
https://linustechtips.com/topic/355085-help-deciding/
@Thenothing
They won't take up more than 500gb of storage, but in general more storage is better because you will always want more games and programs etc in the future. Problems with drives only really arise when you go above 3tb of capacity, or you buy segate drives.
:)xD9_9:D:PB|
https://linustechtips.com/topic/355085-help-deciding/#findComment-4822756
dont waste money buying a WD black and get a seagate barracuda instead
they are almost half the price for the same capacity
https://linustechtips.com/topic/355085-help-deciding/#findComment-4822757
Hi there @Thenothing!
I would say it pretty much depends on the games you want to play - if you think you'll be needing more storage capacity, then get the 2TB drive, and if not you can easily go with the 1TB. I personally will get the bigger one because it's better to have more storage than having not enough when you need it.
Hope this helps and cheers! :)
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
https://linustechtips.com/topic/355085-help-deciding/#findComment-4831165
