I got a message earlier from a friend that gets RAW Returns (customer returned without specifying a reason), they have been offered a Creative Sound Blaster Z.
My motherboard is a Gigabyte GA-990FXA-UD3, I have had it 2 years and the sound is brilliant, but I reinstalled windows about 3 months ago and since then I cannot install the correct Dolby software (Dolby Home Theatre V4) instead I can only install lower end software with less options, which doesn't sound as good.  I have spent days removing and installing drivers, and going from forum to forum and not finding a solution.
Creative Sound Blaster Z: NEW = around £60+
This one I have been offered is UNTESTED, price is £15.  Now they sell a lot of raw returns, and all I see is positive feedback from their customers.
Is this worth chancing for £45 cheaper than the retail price??
I have a 5.1 surround system.
If you have this sound card, is it good? (I am also reading reviews on it)
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/354969-creative-sound-blaster-z/
i would give it a shot...
the quality is worse than a xonar, but still will give a lot of options that your motherboard wont give you
https://linustechtips.com/topic/354969-creative-sound-blaster-z/#findComment-4821383
I got one and the sound is fantastic, with my surround sound speakers and on my regular headset.
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/354969-creative-sound-blaster-z/#findComment-4821424
Thanks :D I bought it, will let you know what it is like. :D
Addon Customs -
https://linustechtips.com/topic/354969-creative-sound-blaster-z/#findComment-4822861
  • 3 weeks later...
Well I received it yesterday, it works perfectly and I LOVE IT!!
Addon Customs -
https://linustechtips.com/topic/354969-creative-sound-blaster-z/#findComment-4956639
