Creative Sound Blaster Audigy FX 5.1 or Asus Xonar DGX What to Get?
Solved by KaminKevCrew,
a better input and output for all of my audio devices.
Sound: Razer Kraken Pro, Marshall Major FX, Razer Hammerhead Pro, Audio-Technica ATH-M40X, Sennheiser HD 558, Antlion Audio ModMic 4.0
the one that my motherboard has sucks, plus i am so lucky that the drivers for the Creative Sound Blaster E1 Dac/Amp doesn't work on my pc (Bummer) supposedly problem fixed by that.
Well, I would definitely say that if your computer doesn't work with one creative product, it may not work with another one, so you should go for the Asus...
