Replacing NH-D15 fans
Ahsan041
Are there any alternatives to the included fans in NH-D15? The alternative fans should not reduce the performance of the cpu cooler, at least not by much.
I don't see why not, as long as you can mount the fans on the heatsink with rubber anti-vibration and the metal hooks to the fan itself.
Silent wings
Silent wings
You are talking about be quiet, right? I was thinking about them too, but will it affect the performance of the cpu cooler?
between the cheapest fans and the most expensive ones you are looking at a 1-3c difference so no
Thanks mate. But do you mean that the 1-3c difference occurs if I put the silent wings instead of the already present noctua fans? then I am okay with that.
yes and may be 1-3c lower even
The SW2 performs worse than NF-A15's.
The included fans are virtually silent and perform better than almost any fan out there.
The Noctua fans are the best around in my opinion.
But to answer your question, of course you can change the fans out.
