VM for Vista help?
Go to solution Solved by blu4,
Get a vista ISO and get VMware player
1. Install VMware
2. Select "Create a New Virtual Machine"
3. Pick the installer disc image and select your vista ISO
4. Enter product key and local user credentials
5. Select a path to where the VHD (virtual hard drive) will be stored
6. Select the VHD size (keep it split into mutiple virtual disks)
7. Click Finish.
8. Start the VM and treat it as a normal computer
9. Profit
You're welcome, it's quite easy. Let me know if you need more help.
I really really want to play Halo 2 but I don't got no console and don't fancy buying one just for Halo so I need a VM to run Vista as Halo 2 won't run on my Windows 7 or 8..
Plz help me find an easy guide or explain to me easily how I can install a VM for Halo 2, thnx <3
https://linustechtips.com/topic/352300-vm-for-vista-help/
Are you using Windows 7 or 8?
And have you otherwise tried running the game with some service pack?
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4789369
I tried everything so VM is only option..
Windows 8.1 atm
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4789377
1. Install VMware
7. Click Finish.
9. Profit
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4789385
1. Install VMware
7. Click Finish.
9. Profit
Sweet thanks!
Can I use a.......... differently acquired product key.. (HUSH DON'T TELL ON ME)
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4789392
Windows 8.1 atm
Hyper-V should be installed standard on W8, so you can use that as virtual machine program.
You can make a new virtual machine and configure it (like giving it a virtual hard disk, setting the network adapter, etc.)
You can probably follow this:
https://www.youtube.com/watch?v=hOegMFeeitw
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4789393
Hmmm that might be an option too.
Would you recommend @blu4 over your answer?
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4789402
It's disabled by standard on Windows 7 and 8 but it can be enabled. I'd just use VMware, it's less complicated and faster to use on a normal computer. I find that HyperV works better on a server rather than a normal desktop. I use VMware personally at home and HyperV for work servers.
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4789411
Yeah, you can do that too.
It's pretty much the same as I recommended, but with VMware instead of Hyper-V.
I recommended Hyper-V because it's standard with Windows 8 and because I have never used VMWare
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4789419
Okies blu4 it is then :P
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4789422
1. Install VMware
7. Click Finish.
9. Profit
Also can I just drag and drop files in to the VMed OS?
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4811942
You can set-up a shared folder withing the OS settings and drop files there or you can share your entire HDD.
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4811947
Teach me so I can get Halo 2 on to the vista os :D
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4811953
Right click on your VM
Go to Options
Click on shared folders
Always Enabled
Click add
Go through wizard
Profit xD
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4811961
Go to Options
Always Enabled
Click add
Go through wizard
Profit xD
Right click where tho....
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4811963
A VM's emulated 3D acceleration is a far cry from a real GPU so I would not get my hopes up on any decent FPS and/or grahpics if the games runs at all. It's possible to use GPU passthrough into a VM for full 3D acceleration but that needs specific hardware and a Type 1 hypervisor.
I can hope :P
https://linustechtips.com/topic/352300-vm-for-vista-help/#findComment-4812044
