Ive seen this a couple places....and i like creating/ having odd cases. sould something like this be feaseable ? the dust would be a NIGHTMARE but what do ya think? picture added if ya havnt seen it yet. i wouldnt do it the same way ofcourse. certainly wouldnt use rubber bands and zipties...i have better equpiment at my disposal. .. but yeah thoughts?
also in b4 in the wrong section...seemed right thought. sorry mods if it is.
"1 shot 1 kill. or in my case 500 shots and a questionable death" ~ Carlos Hathcock + Ryouichi
"Because its windows... it just happens..." ~ G33k 4 L1F3
My Build....sorta. close enough http://pcpartpicker.com/p/YMG4mG
https://linustechtips.com/topic/352270-cage-case/
Well, as you said the dust would be pretty annoying to say the least.
And you would have to go very differently about airflow and fan placement in general.
I think you can compare this with an open test bench possibly
https://linustechtips.com/topic/352270-cage-case/#findComment-4789027
Seems pointless and stupid but hey thats just my opinion :D
https://linustechtips.com/topic/352270-cage-case/#findComment-4789036
the dust...i have a way to counter it believe it or not. and yeah the air flow....other then ambient airflow. will have to be very thought out.
yeah its basically a test bench...but this would be a very odd build. and i like this kinda stuff.
its honestly between this and throwing a build into ...well. ill post it later maybe ;)
pointless? probably. stupid ehhh probably not. would be nice for showcase computers. not full cage but something like the sort.
https://linustechtips.com/topic/352270-cage-case/#findComment-4789040
I think the airflow will be great
if not i could just...
A cage is such a great playing ground for a design. I would move from the archetypical tower build and perhaps try something modular.
well YES. thank you. i wouldnt build a typical case like rectangle...it would be connected via 4 panes that could be disassembled and put into other positions. the picture is just.....a very rough draft for such an idea.
also it looks like thats an 1990's mobo
https://linustechtips.com/topic/352270-cage-case/#findComment-4789066
-snip-
Be sure to make a build log if you do.
How so, if I may ask?
(Or is my sarcasm meter broken??)
https://linustechtips.com/topic/352270-cage-case/#findComment-4789068
It wouldn't block any noise so it would be loud.
well....when you have 2 airconditioners. and a tv blaring....computer noise isnt a problem.
https://linustechtips.com/topic/352270-cage-case/#findComment-4789083
Still not enough for a FX 9590  ;)
Eh?
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/352270-cage-case/#findComment-4789102
Eh?
You said the airflow would be great, why do you think that??
https://linustechtips.com/topic/352270-cage-case/#findComment-4789107
nothing to block the air at all mini c: put a regular fan up to it and you're fine. and poh :I i have a 5830....i know heat.
i WOULD immagine cleaning it to be a little like this.
https://linustechtips.com/topic/352270-cage-case/#findComment-4789131
I do that every day my friend, everyday a dude with a pc like that comes in..
ive worked on a couple that i swear to god ive seen a new species of dust.....like i saw it breathing
https://linustechtips.com/topic/352270-cage-case/#findComment-4789221
Because its so airy, I mean y'know all the holes and stuff
the things i could say.
it would also let dust in...but like a fine mesh sheild would stop alot of it...and itd be easy to clean too.
https://linustechtips.com/topic/352270-cage-case/#findComment-4789708
Airflow is pretty much all about leading the cold stuff next too all the components, so it picks up the hot air and brings it outside of the case.
With an open case all the warm air just goes up a bit (warm air floats up more than cold air..).
Than again, I am not an expert on this..
https://linustechtips.com/topic/352270-cage-case/#findComment-4789711
The fans would blow dust away too
With cool air coming from all directions I think that wouldn't be a problem  ;)
https://linustechtips.com/topic/352270-cage-case/#findComment-4789774
would suck it in too :P
also 73 fans should be enough....right?
https://linustechtips.com/topic/352270-cage-case/#findComment-4789795
Ya only need this
new_strong_style_color_b82220_industrial
i see your standing fan and i raise you. the fan to cool the radeon 5830
https://linustechtips.com/topic/352270-cage-case/#findComment-4789897
