I couldn't find a thread like this, and I'm interested to find out.
So, which design od the 780 coolers is the best? twin frzr, direct cu 2, windforce, acx... ?
I imagine this would be very important since the 780 implements the GPU Boost 2.
Intel 4770k@4.6GHz, ASUS ROG Maximus VI Hero, Kingston HyperX Beast 2x8GB 2400MHz CL11, Gigabyte GTX 1070 Gaming, Kingston HyperX 3k 240GB - RAID0 (2x120Gb), 2xWD 1TB (Blue and Green), Corsair H100i, Corsair AX860, CoolerMaster HAF X, ASUS STRIX Tactic pro, Logitech G400S, HyperX Cloud II, Logitech X530, Acer Predator X34.
https://linustechtips.com/topic/35161-best-780-cooler/
I've heard only good things about the ACX Cooler. Can't speak for the others, tho.
Twin Frozr usually gets loud for the high end cards, so does direct cu2. They both seem to reach their limit on the bigger cards. Don't know if there where tweaks made to them for the 780
The windforce cooler seems to be a new version specially made for 780, maybe it's better then old versions. At Computex they said it's made to handle upto 450 Watts if i remember correctly
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-450437
The windforce cooler seems to be a new version specially made for 780, maybe it's better then old versions. At Computex the said it's made to handle upto 450 Watts if i remember correctly
Yeah, I saw the windfore cooler dissected, rather impressive. But as i have 2 bad experiences with gigabyte's coolers I think I'll pass on it. But it does look like a first class performer.
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-450462
EVGA, MSI or Gigabyte. Pick on of them, asus would of been a good choice however their customer service is the biggest pile of **** ive seen so they are out.
Listen if you care.
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-450687
May get TF5 with the 780 lightning
[spoiler=Current Rig:]i5-4670K @ 4.4 Ghz on 1.3v | MSI Z87I | GTX 780 @ 1150 Mhz | 2x8GB ADATA XPG | Samsung 840 250GB SSD | CM V700 PSU | Custom Watercooled in a Caselabs S3
[spoiler=Peripherals:]Mad Catz R.A.T. 7 | Corsair K70 | Sennheiser Urbanite headphones | Corsair Vengeance MM200 | Asus PB278Q + Samsung 22"
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-451265
I have a direct cu 2 670 and it is so quiet I can't hear it in my rig. Not sure what direct cu 2 cards you have had bad experiences with, but I have never seen any that are loud.
I would say direct cu 2 and twin frozr, the MSI 780 lightning (twin frozr) looks the best though.
Fractal Design Define S, i7 3770K @ 4.5GHz, Noctua NH-D14, Asus Sabertooth Z77, EVGA 980Ti SC+, 4x8GB Corsair Vengence 1600MHz, EVGA P2 1000W, Creative sound blaster Z, 2xSamsung 850 120GB RAID 0, 2xWestern Digital Caviar Black 1TB Other stuffs: BenQ XL2411t, LG Flatron M2262D, Ducky Shine 3, Logitech G400s, Steelseries QCK Heavy, Beyerdynamic DT770 pro 80ohm, Shure SE215, Blue Snowball
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-452011
i did this thread and it had the same title mine had a ? at the end tgh... youu littllllleeeeee
He is the hero this forum deserves but not the one it needs right now.So we'll hunt him because he can take it because he is not our hero he is a silent guardian
a watchful protector A Dark Knight
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-452043
well the answer is
1)arctic cooling
2)TwinFrozr
3)ACX
4)DCUİİ
in my opinion cuz the card has to look good too (you can tell it cuz gigabyte windforce is not on the list eventhough it it the best cooler out there :p)
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-452048
I got 2x 660 DCUII in my rig, they are awesome, but from what i've heard the 680 can get quite loud with the same cooler.
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-452172
I can image the triple slot ones being more noisy, the 4gb one that is two slot is probably better.
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-452175
I think everyone is just gonna say whichever brand they like most makes the best cooler.  unless someone tests every cooler on the same gpu I don't think we'll really know.  arctic cooling makes that liquid cooler, so thats prolly better than the air coolers, but other than that they're more or less the same
HP something | 5600X | Corsair  16GB | Zotac ArcticStorm GTX 1080 Ti
CaseLabs SM8 | EK Supremacy | UT60 420 | ST30 360 | ST30 240
Gentle Typhoon's and Noctua's and Noiseblocker eLoop's
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-452574
I love my acx's, the hottest it ever gets is 79 degrees on my top card, but the soundcard is directly underneathe it and it cant get enough fresh air I believe, the bottom card has an open air delivery and gets 64 degrees at its peak.
Edit: this is with a 60 mhz OC on the core and a 300mhz memory OC
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-453339
I couldn't find your thread, although I'm not surprised :)
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-453790
lol why do we have to think the same all tha time... you must be robin arent ya?
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-454576
Dick grayson mind you... Or Owlman, the one from earth 3 :D
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-457033
A few days ago I read this topic when I was waiting for my Asus 780 DC2 to get here and was going to start saying how amazing the DC2 is and how its soooooooo much better etc. etc. etc.  Then I read your post and figured you might be right, people are just saying whatever there fav brand is, so I thought Id wait to reply here until after I had gotten my 780.
Honestly, I was a bit surprised from the moment I put it in ... surprised as in disappointed =(.  Now I will be the first person to go on and on about how amazing Asus DC2 coolers are, they always seem to be the coolest cards and the most silent.  Coming from a 670 DC2 which is whisper quite, I was very very disappointed with the 780 DC2.  Cause it def. does not live up to the 670 DC2, thats for sure.  The Asus 780 DC2 acoustics was closer to my old reference 570, then it was to any aftermarket cooler.  The temps were still pretty good, I never went over 68degrees when gaming on ultra, but I just could NOT get over how loud the card was.  After spending 700$ on it (670 on card 30 on warranty), it was just too loud for me.  I dont know if I got a defective one or what, but I am RMA refunding it back since it is in my first week of having the card.
I still plan on going with an Asus ROG mobo and sound card, but after this 780 DC2, I dunno about graphics card. Its really turned me off from them which is upsetting because I was the biggest Asus fan boy ever lol, and now not so much.  Maybe I am too much of a silence freak but when the fans went over 40-50% speed, it just sounded like a jet was taking off in my PC.  I am considering the MSI TF 780 now, if I do get that one then ill see how much more loud / quite it is compared to the DC2 and then I guess Ill have a better idea of how good / bad the 780 DC2 is.
https://linustechtips.com/topic/35161-best-780-cooler/#findComment-469215
