I have a budget of $300 left for my cpu.  I want a cpu that has a lot of upgrade paths, able to game while streaming at the same time (gonna have a GTX 970 as GPU), Cost around $300 or less if possible.  I thought about a i5 4460 or 4690  OR Amd FX 6300 or Amd Fx8350.  What do you think of the cpu's I thought of, and what are some other cpu that can fill my needs?
https://linustechtips.com/topic/350856-cpu-for-gamingstreaming-and-general-uses/
its not worth going down the amd line because amds cpus raw power compared to an intels just isnt there grab an i5 4690k or 4690.
askdjfasdf
you never know what zen may bring ( ͡° ͜ʖ ͡°)
But seriously, as of right now, 4690 is your best option.
I am conducting some polls regarding your opinion of large technology companies. I would appreciate your response.
Microsoft Apple Valve Google Facebook Oculus HTC AMD Intel Nvidia
I'm using this data to judge this site's biases so people can post in a more objective way.
just like we may never know how many licks it takes to get to the tootsie roll center of a tootsie pop.
askdjfasdf
4690 or 4690k for overclocking. The AMD CPUs have no upgrade path and the 4690 is just plain better!
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
If you have $300 for a CPU, an i7-4790k should fit the bill.  Or is that $300 for CPU and mobo?  An i5-4690k will be plenty, but an i7 will be that end of the line, best available on this platform.  Either will last you a very long time.  You will need a Z97 mobo for either.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
I live in Canada and the price for the i7 4790 is $385.  Also can the i5 4690 or 4460 live stream while playing games?
i5-4690k will do a great job for your needs and will not bottleneck your 970. I highly reccomended and also you could upgrade the i7-4790k with a beast of a cpu.
CPU: AMD FX 8320  CPU Cooler: 212 Evo GPU: Asus GTX 750 Ti @ 1400MHz RAM: Crucial Ballistix Sport 8GB (2x4gb) MOBO: ASUS M5A97 R2.0 Power Supply: Evga G2 650 Storage: Western Digital Caviar Blue 1TB, San Disk Ultra 240 GB SSD Case: Corsair 230t Orange
Pretty much and 4th generation quad core i5 (Don't even think they make a dual core i5) will do the job just fine. There have been posted some good recommendations
I would NOT go for an AMD FX seires cpu, because they are out-dated (most of them) and for what I know, all 4th gen i7 Socket 1150 CPU are better then any FX-series CPU. In more ways then performance.
Ahh, Canadian dollars.  Yea, an will be able to do both of those things.
