Alright. I need some advice. Will a CX750W be enough for
Moderate OC 2600k
2x GTX 760s?
The thing is, the 2 GTX 760's that I have require 1 6-pin connector. Yes. I have 2 GTX 760's that can be fed with 2 six pin connectors.
But the thing is, I don't know anything about power supplies. I have 1 550W 80+ Bronze PSU right now that apparently can't provide enough power for 1 of the 760's that I'm using for now. So I'm really now sure if a 750W will send enough power through 2 six pin connectors. Help please?
CPU: i7 2600k @4.2GHz GPU: GTX 660 Power Supply: EVGA SupernovaNEX 750W 80+ Bronze RAM: 32GB G. Skill Ripjaws X
https://linustechtips.com/topic/350704-please-help/
If you can, can you maybe recommend some specifics under ~90$?
A decent 650w would already be plenty. What kind of dollars are you using?
https://linustechtips.com/topic/350704-please-help/#findComment-4769818
https://linustechtips.com/topic/350704-please-help/#findComment-4769855
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139060&cm_re=corsair_cs-_-17-139-060-_-Product
That one is also good, 80+ gold instead of bronze, saving on pwr costs, and it is semi-modular. if that is too expensive (don't want to do the rebate), a 550w version would also be good.
If I've said something wrong, please correct me
My Builds:
Peripherals:
Keyboard: Roccat TKL Pro Cherry MX blue, Mouse: Roccat Kone XTD, Headset: Currently apple earbuds, planning to upgrade to hyperx cloud or hyperx cloud 2
Really Old Desktop
 Processor: Intel Core i7 920, Motherboard: Gigabyte GA-FX58-DS4, RAM: 9GB Corsair XM3 (3*3GB in triple channel) 600 or 800mhz, Graphics Card: Asus 8400GS passive, Asus GT630 4GB if i can get it working, Case: Cheapo Throwout case with most of the standoffs missing, HDD: Some old 80GB hard drive, PSU: Thermaltake Toughpower 550w, Monitor: 32" Kogan TV, OS: Fedora 13
 Laptop Which I Use For Everything:
Processor: Intel Core i5 3337U, RAM: 8GB (2*4GB) 1600MHZ, Graphics Card: Nvidia 710m HDD/SSD: WD Black2 Dual Drive, OS: Windows 8.1
 40 GB/s Network Tester
Processor: Some really good Intel Core i3, Motherboard: Gigabyte GA-H67N-USB3-B3, Ram: Corsair Value Select 4GB (2*2GB) 1600MHZ, Graphics Card: Integrated, Case: Some 1U rackmount mini-itx case with no front bays, HDD: Seagate Momentus 5400, 250GB 2.5" 5400RPM, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 40Gb/s QSFP+ PCIe 3.0 8x NIC, Monitor: any ones lying around, or 32" Kogan TV, OS: CentOS 6.2 (I Think)
Planned 100Gb/s Newtork Tester
Processor: Intel Core i7 4790k, Motherboard: Asus Maximus VII Impact, Ram: Kingston or G.Skill 8GB 2400MHZ Low Profile, Graphics Card: Integrated, Case: 1U Rackmount ITX case, HDD: Samsung 850 EVO 120GB, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 100Gb/s PCIe 3.0 16x NIC, Monitor: Any lying around or 32" Kogan TV, OS: Fedora 22 or CentOS
https://linustechtips.com/topic/350704-please-help/#findComment-4769885
Would these really work for GTX 760 SLI?
Everything listed so far should be fine for your system.
https://linustechtips.com/topic/350704-please-help/#findComment-4769990
