The compatibility can be resolved with a better case, I recommend the Corsair 200R.
But yeah, for that budget at least go with the FX-6300 and an AM3+ motherboard.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/348882-problem/#findComment-4748066
No but I would recommend dropping that keyboard and getting a better build
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor ($103.99 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard ($43.99 @ SuperBiiz)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory ($52.99 @ SuperBiiz)
Storage: Western Digital BLACK SERIES 750GB 2.5" 7200RPM Internal Hard Drive ($59.99 @ SuperBiiz)
Video Card: Sapphire Radeon R9 290 4GB Tri-X OC Video Card ($239.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($37.99 @ SuperBiiz)
Power Supply: Corsair Builder 750W 80+ Bronze Certified ATX Power Supply ($49.99 @ Newegg)
Other: Blue Snowball
Total: $588.93
Generated by PCPartPicker 2015-04-15 19:24 EDT-0400
Steve
https://linustechtips.com/topic/348882-problem/#findComment-4748074
I need a keyboard because I do not have one.
Total: $588.93
Go here :)
https://linustechtips.com/topic/348882-problem/#findComment-4748084
http://pcpartpicker.com/p/xX7wXL
With an interesting price too.
Solitaire.
https://linustechtips.com/topic/348882-problem/#findComment-4748107
The BlackWidow is a great keyboard, but it is a bit pricey, I would focus on internals before peripherals.
Solitaire.
https://linustechtips.com/topic/348882-problem/#findComment-4748114
and it says it needs a bois update and this my first build so I don't know what to do there.
With this you wont have to worry about having to update anything
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor ($113.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.49 @ OutletPC)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case ($24.99 @ NCIX US)
Keyboard: AZIO PRISM Wired Slim Keyboard ($27.89 @ Amazon)
Total: $606.32
Generated by PCPartPicker 2015-04-15 19:34 EDT-0400
Steve
https://linustechtips.com/topic/348882-problem/#findComment-4748139
Cores mean nothing
to a point, i believe at least a quad core is necessary, which is why i recommended the 6300 instead of an I3.
and it was only $10 more than 4300
Solitaire.
https://linustechtips.com/topic/348882-problem/#findComment-4748198
i3 is hyperthreaded
The 6300 will fall apart in newer games
Intel Core i7 9700k - EVGA FTW GTX 970
https://linustechtips.com/topic/348882-problem/#findComment-4748203
