what CPU you got?
it normal to see different temps for each cores depending on the loading
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/348526-abnormal-temps/#findComment-4743584
Woah woah... Slow down. What's you CPU model and you are saying that one core reports 0C?
AMD CPU i guess
https://linustechtips.com/topic/348526-abnormal-temps/#findComment-4743590
what CPU you got?
i have i5 4690k i didnt overclock i want to post image here but i dont know how so. im new in forumns it just freaks me out im using MSI afterburner.
https://linustechtips.com/topic/348526-abnormal-temps/#findComment-4743593
use CPU-Z ID and HWMonitor or Intel Extreme Tuning Utility
report back the temps
take a screenshot and attach to the post
https://linustechtips.com/topic/348526-abnormal-temps/#findComment-4743597
