980 + G10 Memory Temps
Solved by Joemoma,
i took the shim off, and modified the EVGA Thermal plate (sanded the points of contact interfering)
i have it at stock / Default self overlocking
ambient is around 75F (24C)
yes, pump is plugged into the Motherboard under 1 of the Chassis fan connectors
1 fan, in pull config, and its a Noctua NF-12 (for radiators) is spinnings around 1050 RPM
Replaced the rear exhaust fan location with the Radiator as an exhaust
