I Don't see why the Playstation 4 needs to be oil cooled, It's not a high performance gaming PC so it would not need to be oil cooled, its just a big waste of money.
Besides there will be no way to monitor the PS4's Temps so you will not be able to tell if its overheating ( if it even does ) Don't waste you money on something like this for a Playstation because it does not need it
"Life's too Short, Use Express Install" Express install subject to spying
                                        -Microsoft 2015
https://linustechtips.com/topic/347672-oil-cooled-ps4/#findComment-4793751
you will have to replace the HDD with a SSD and mount the disk drive ouside
I wouldn't bother replacing the HDD with an SSD either the performance gains on a ps4 with an SSD are minor at best, not worth the cost.  SSHD On the other hand is cheaper and you do get noticeable performance gains.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/347672-oil-cooled-ps4/#findComment-4793939
If you put a HDD or sshd in mineral oil it will die a terrible death. That's why you'd have to replace the HDD, unless you can mount it outside the oil.
Atom14 [Corsair] i5-4690K | Corsair H110i GT | MSI Z97S SLI Krait | 16 GB Team Group DDR3 | Samsung 850 EVO 250GB X2 | EVGA SuperNOVA 850W 80+ Gold | Corsair K95 RGB | Corsair M65 RGB | EVGA ACX 2.0 GTX 980Ti
Corsair KXX RGB Keyboard Cover Mod Make your own using my templates!
https://linustechtips.com/topic/347672-oil-cooled-ps4/#findComment-4794163
not what I meant. an hdd cant work in oil
https://linustechtips.com/topic/347672-oil-cooled-ps4/#findComment-4794167
