So this is a real issue there is about 6 peacocks that have an orgy everyday. Now if you have seen peacocks do it you know it's the loudest thing in the world. It's been happening for about 3 weeks straight and they won't stop. Any suggestions?
https://linustechtips.com/topic/347215-peacock-issues/
deal with it, bitch.
https://linustechtips.com/topic/347215-peacock-issues/#findComment-4727037
Well I'd say this is a golden opportunity for a niche p****graphy site :nodding:
Joking apart, I'm not sure...is there some kind of animal control organisation you could call?
Edit: otherwise I guess just wait out their mating season?
"I try to put good out into the world...that way I can believe it's out there." --CKN                  “How people treat you is their karma; how you react is yours.” --Wayne Dyer
[Needs Updating] My PC: i5-10600K @TBD / 32GB DDR4 @4000MHz / Z490 AORUS Elite AC / Titan RTX / Samsung 1TB 960 Evo / EVGA SuperNova 850 T2
https://linustechtips.com/topic/347215-peacock-issues/#findComment-4727104
Er what??
Why do you have peacocks?
Why are they having an orgy?
Are they your peacocks?
https://linustechtips.com/topic/347215-peacock-issues/#findComment-4727139
Uhh... Wat... why do you have peacocks...
Intel i7 4702MQ| Nvidia GTX 850M| Kingston 16GB DDR3 1600Mhz| Acer VA70_HW (mobo)| 1TB WD Blue| MATSHITA DVD-RAM UJ8E0|1600x900 display|Win 8.1
Intel i5 4690K @Stock| Sapphire 390 Nitro| Hyper X Fury 2x4GB| MSI SLI Krait z97| Noctua Nh-U12S | 850 EVO 256GB| 2TB WD Black | CM V 850w| Enthoo Luxe
If you want to tag me or any person with periods do: @[Member='Name]
https://linustechtips.com/topic/347215-peacock-issues/#findComment-4727174
I don't. It's literally someone else's. Thanks for the replys. We will probably head over there to see if they will stop. Cheers!
https://linustechtips.com/topic/347215-peacock-issues/#findComment-4727197
Uhh, I wish you good luck.
https://linustechtips.com/topic/347215-peacock-issues/#findComment-4727262
  • 3 weeks later...
Are you saying a cat Rekt the peacocks?
No, for some reason the peacocks stopped over 2 days. I think enough ppl actually complained about them lol. I just needed a thread for testings. Cheers ^^
https://linustechtips.com/topic/347215-peacock-issues/#findComment-4882071
Testing what? :P
Well Im actually quite new to this forum, so I'm testing the uploading functions of it.
https://linustechtips.com/topic/347215-peacock-issues/#findComment-4882083
Ooh okay. Well basically and then the url here and you end with
And then you place an image. :P same with quote but you write quote instead of img.
What?
https://linustechtips.com/topic/347215-peacock-issues/#findComment-4882116
