choose the asus setup
CPU: I5 7400 | Motherboard: MSI H110M  | RAM: 16GB G-Skill 2400mhz  | GPU:  NVIDIA  MSI Gaming 4G GTX 970 | Case: Tecware Quad | Cooling: Stock| Storage: Kingston 120gb SSD, 1TB Drive ,  | PSU: Seasonic 620 Watt 80+ Bronze Full Modular | Display: Devant 50 Inch Smart TV   |
The asus setup in the first folder you see when you unzip is the main executable, run that and it will call up the other installers it needs once it scans your system
If your board has a Gigabit LAN, install that one
For all downloads, look at the version number and the date, you will see which are the latest versions because the version number will be higher / date will be newer, you only need to install the latest version for each piece of hardware
Or
Just auto-run the CD and do an express install.
