I can't remember who makes them, but I recall seeing in either the CES or another tech show coverage a PC case fan / cooler fan manufacturer was making their motors with 6 coils instead of the normal 4 for better efficiency. It was represented by a graphic on the fan itself. I looked back though the LinusTechTips and NeweggTV videos from this year, but couldn't find it. Does anyone know who was doing this with their fan motors or am I losing my mind?
https://linustechtips.com/topic/346836-6-coil-fan/
Noctua... And I'd assume other manufacturers. The iPPC at least has them currently available.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/346836-6-coil-fan/#findComment-4722081
noctua industrial PPC fans
and they are loud, so if you want a quiet PC dont buy them
https://linustechtips.com/topic/346836-6-coil-fan/#findComment-4722104
Depends... under ~1200 they aren't that bad.
https://linustechtips.com/topic/346836-6-coil-fan/#findComment-4722114
yeah at 50% speed they arent loud, but youre also getting 50% performance
in which case you might as well buy fans that run at 1200rpm and have better performance...
https://linustechtips.com/topic/346836-6-coil-fan/#findComment-4722127
Indeed.
But, at least in my system, they are directly controlled my CPU temp. So they only are ramped when everything else is too.
https://linustechtips.com/topic/346836-6-coil-fan/#findComment-4722140
Well, they're called industrial for a reason. If you're only using them as average Joe PC fans, might as well save your money and get something like Be Quiet's Silent Wings 2s, which perform better and are cheaper then industrial Noctuas
"Rawr XD"
https://linustechtips.com/topic/346836-6-coil-fan/#findComment-4722144
Indeed.
true, but some people dont want loud fans even at 100% load :)
https://linustechtips.com/topic/346836-6-coil-fan/#findComment-4722145
My rig is in the same room as my server rack, and is used for work more than anything. They fit for what I used them for.
I'd rather cool temps over some noise... and I got low temps and quite acceptable noise. It's all how you deal with your setup, can make a world of difference.
https://linustechtips.com/topic/346836-6-coil-fan/#findComment-4722161
you have a rack server in your room?
lol well that explains why youre not bothered by a bit of noise :P
https://linustechtips.com/topic/346836-6-coil-fan/#findComment-4722183
I can still hear my kids upstairs just fine. It's just a micro-cluster.
https://linustechtips.com/topic/346836-6-coil-fan/#findComment-4722190
  • 2 weeks later...
No. I remember there being a sticker on the front of the new fans showing 6 radial lines. It's gotta be another brand, but I still can't find the video for it.
Probably BeQuiet!
SW2'S may be a bit quieter but they definitely don't perform better than NF-A14's.
https://linustechtips.com/topic/346836-6-coil-fan/#findComment-4816998
  • 1 year later...
