Hey guys,
So recently i have been monitoring my cpu temp and i have found some weird things (not sure if they are normal). So I am using a stock AMD heat sink on my A8-5500 and i under-clocked it to 1.4 GHz and just browsing the web with Skype open (not signed in), CPUID open, and catalyst control center open it is at 49 degrees Celsius. When i put it to 3.4 GHz and run Prime95 i t reaches as high as 88 degrees. Is there a problem or do most A8 processors run this hot? Thanks.
Build: CPU: i7-4790k @4.4 GHz 1.2v | GPU: Sapphire R9 380 Nitro | Memory: 16GB Evga SSC | Storage: 250GB 850 Evo, 1 TB Toshiba HDD | Mobo: Gigabyte GA-Z97X-Gaming 7  | Cooling: Aigo T120 RGB | Case: NZXT S340 | PSU: Antec HCG 520w | OS: Windows 10 | Keyboard: Corsair K70, Cherry MX Reds | Mouse: Logitech G600 | Monitor: LG 27UD58-B | Headset: Audio-Technica M40x w/ Modmic and Bravo Audio V2 Tube Amplifier
https://linustechtips.com/topic/346722-amd-a8-5500-heat-problem/
That's some pretty normal temps. Prime 95 is meant to get your cpu to its max load, i.e. high temps.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/346722-amd-a8-5500-heat-problem/#findComment-4720821
Hey guys,
They have notoriously wrong sensors, It's completely fine.
PEWDIEPIE DONT CROSS THAT BRIDGE
https://linustechtips.com/topic/346722-amd-a8-5500-heat-problem/#findComment-4720829
OK thanks guys.
https://linustechtips.com/topic/346722-amd-a8-5500-heat-problem/#findComment-4720839
